BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis M550i brake specifications?
      01-09-2019, 06:34 PM   #1
Mach550
Mach550's Avatar
472
Drives: 2019 M550i
2019 BMW M550i  [8.00]
I'm having difficulty finding the specs on the brakes like the rotor size.
      01-09-2019, 06:44 PM   #2
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
M Performance are Front 395x36 Rear 370x24
4-piston front and 2-piston rear.
EDIT: Other sources have the front at 374x36 and rear 345x24.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
540iSUP704.00
      01-09-2019, 07:37 PM   #3
saporitj
281
Drives: 2019 540ix M Sport
I think you have M Sport and not Performance but if your thinking of switching to Performance here is a attachment about installing M Performance brakes in a G30.
Sorry can't attach .pdf. If your interested maybe I can PM a pdf. Anyway here is screen shot of first page.
JS
      01-10-2019, 01:43 PM   #4
Mach550
Mach550's Avatar
472
Drives: 2019 M550i
So the OEM parts have the following specs
Front 374X36
https://www.etkbmw.com/bmw/EN/search...iX/ECE/34_2471
Rear 345X24
https://www.etkbmw.com/bmw/EN/search...iX/ECE/34_2443
M5 is 395X36 front and 380X28 rear (steel) and 400X38 front 380X28 rear (ceramic)
540iSUP704.00
      03-10-2019, 04:54 PM   #5
12bmw535xi
122
Drives: 2019 M550
Can you please e-mail it to me as well? My e-mail is mc061680@gmail.com or PM it if easier. Thank you!
      03-14-2019, 06:50 PM   #6
saporitj
281
Email sent
JS
      03-15-2019, 07:33 PM   #7
12bmw535xi
122
Drives: 2019 M550
Email sent
Thank you!
      04-15-2019, 03:41 PM   #8
Warp Ten
Warp Ten's Avatar
642
Drives: 2019 BMW 540xi
I am curious about this. Does the pdf indicate that a new master cylinder is needed when the M Sport brake package is added? I discovered that the part number of the standard 540 master cylinder (last three digits -095) is different from that of the master cylinder on the M Sport brakes on a 540 or M550 (-616). When I search on the internet for the upgrade there is no mention of the master cylinder needing to be changed if you upgrade a standard 540.--Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
      01-13-2022, 04:54 AM   #9
Knifeedge2k1
153
Drives: BMW G30 520i 2019
I know I'm digging up an old thread but main thing would be pedal feel
If you upgrade from the bone stock setup (34 33 6 881 095 Master Cylinder & 34 33 6 874 524 Brake Booster) to the bigger diameter discs and multi-piston sport brakes then you'll have more pedal travel and a "spongier" feel.
You don't HAVE to upgrade the master cylinder/brake booster (if you upgrade one you HAVE to upgrade the other) as I'm fairly certain you'll be able to still apply enough pressure with the travel that exists to overwhelm your tire's grip limits.
The "downside" of the smaller master cylinder & weaker brake booster is the spongier feel of the pedal as you'll need more travel in the pedal to move the pads a given distance. If you can still lock the wheels (i.e activate ABS) it's purely a "feel" thing and you won't get any performance benefit from the changeover.
5post
