2010 E91 ABS,DSC,Power steering not working! Need help!
01-05-2019, 01:26 PM | #1 |
Rep 2
So problems began when my DME got water damaged,car was cranking but not starting.After trying to start it for maybe 5 times my dash lit up with warning lights(my guess something shorted).I took DME out,dried it then put it back and it started but was running rough and throttle was not working. So I bought used DME and took it with CAS and old DME to ECU repair shop,guy in the shop told me that he couldn't even read old dme . When I put reprogrammed DME back car started right up,but all the warning lights stayed.
Car drives fine,but I got no power steering,my turning signal dont go back,wipers runing constantly and I cant turn them off,speedo doesnt work,fuel gauge acts up,steering controls not working. I checked every single fuse.Cant connect to DSC with INPA it says No comunication.My guess ABS module gone?or maybe Fuse box?Here is Error codes with INPA,but its in German so I cant understand much..Please help! Engine P0557 U1120 U110C U1118 U1126 U116D U1103 P0503 P0500 JBB A6CA C918 A6C9 C804 FRM E594 932C Last edited by mindau88; 01-05-2019 at 01:37 PM.. |
01-05-2019, 04:46 PM | #2 |
1918
Rep 13,117
Why do you think you would find it in the stereo audio visual sub forum
and not the general forum? If you put in a new CAS and DME it needs to be programmed/synced to the cars Vin and mileage. Also best to install ista D its in English and provides assisted trouble shooting directions and a database of schematics and procedures. https://www.newtis.info/tisv2/a/en/ Put this up on the general board and petition George for help he will give you the best analysis a human could. https://www.e90post.com/forums/forumdisplay.php?f=2 georges links https://www.bimmerfest.com/forums/at...9&d=1539905743 This may help you understand Inpa and Ista d better. diagnostic manual ista/inpa https://bimmerprofs.com/diagnostics-inpa-part-1/ https://www.google.com/url?sa=t&rct=...xo19teM9vkTF-C https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF https://www.bimmerforums.com/forum/s...-P-actually-do Also about e90 post this is the general forum https://www.e90post.com/forums/forumdisplay.php?f=2 The following have links to the very useful sub forums http://www.e90post.com/forums/forumdisplay.php?f=16 http://www.e90post.com/forums/forumdisplay.php?f=378 electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU You can find what those error code mean by dong a google search. Have you checked the fuses? http://knigaproavto.ru/shemy/en/bmw/...x-diagram.html O and you might want to say which engine you have. and mileage on the car. http://bmwfault.codes/ Last edited by ctuna; 01-05-2019 at 08:29 PM.. |
