TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Do I need to upgrade the TCU to MULF for bluetooth audio?
      01-05-2019, 12:36 AM   #1
SteNZ
Australia
Drives: E92 M3, E90 M3, E61 M Touring
Hi there
I've had a quick look around. Sorry if I'm duplicating the same question elsewhere (which I guarantee I am).
My E92 VIN has this listed
S6FLA USB/Audio interface
I have a TCU module installed in the rear (along with a DVB-T module).
I don't have the [software update] menu option in the [settings] menu. I believe a dealer can update the software (at what cost?).
My questions.
What do I need to do to get updated Idrive software?
If I get the update, will this solve BT audio (I have BT phone already)?
If not, what do I need to do to solve the BT Audio connectivity?
Thanks
      01-05-2019, 08:15 AM   #2
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
European radios can be different from US but I will give a guess. You may have a MULF mounted under your TCU in the trunk. Or your USB in the arm rest may hook directly to the back of your radio. A tune2air can get you bluetooth music with your usb/aux
https://www.amazon.com/Bovee-WMA3000...qid=1546697202
Software update in i-drive is only for 2011+ combox which can be retrofited to your car for not much more cost than the tune2air but you need to know how to re-pin connectors and code.
As for playing bluetooth music, a combox can switch between phones on the i-drive screen which a tune2air can't.
      02-01-2019, 10:17 AM   #3
vilord
488
Drives: E91, Tundra, TT, SV650
If you have an iDrive car, you can add bluetooth audio streaming with a combox.
If you don't have an iDrive car, you can only add bluetooth audio streaming with a tune2air or similar, or... another option is one of these doodads:
https://www.ebay.com/itm/Bluetooth-A...lOLJ:rk:2:pf:0
This works with a professional (but *not* idrive/cic) radio to add bluetooth streaming with full steering wheel controls and on-radio displays, and it plugs into the CD changer MOST optical connection, so you get very high quality audio streaming... better than is possible from the aux plug
