01-03-2019, 02:07 PM | #1 |
244
Rep 527
Skipping Gears
230i RWD 6 speed
6 may be a good number of gears for track and highly spirited hiway driving but as a DD 6 is more than necessary. Not a problem and kinda fun. I just skip gears a lot, typically 1, 2, 4, 6 or 1, 3, 5, 6 or even 1, 3, 6. Or if starting out rolling or downhill, 2, 4,6. Downshifting is much more open, with 6,1 being common. Actually I'm leaving out N which gets a good deal of use, accounting for more miles than 1 or 2 or 3 or even 4. |
01-03-2019, 03:01 PM | #2 | |
4413
Rep 3,497
typically 1, 2, 4, then 6 @ ~35 MPH unless going up an incline; less often 1, 2, 5, 6 when going down a slope a 5-speed would be enough on the track 6th is good for 32+ MPG on the highway
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
01-03-2019, 03:47 PM | #3 | |
5556
Rep 5,372
I skip shift often in my 6MT. That's something I dearly love about having a manual. You're in total control. With an auto, you still have to go through all the gears, to some extent.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
01-03-2019, 07:28 PM | #4 |
43
Rep 121
?? The engine shuts off when coasting in gear? Otherwise, how could it use "absolutely no fuel?"
01-03-2019, 08:53 PM | #5 |
Car Geek
3626
Rep 3,594
Yes, with a modern engine that is being mechanically rotated by the transmission, no fuel is injected (or spark triggered in some cases) unless the revs fall to a value just above idle, when no throttle is being commanded. You can see this affect when going down a long hill with no throttle on an engine that isn’t fully warmed up, as the coolant and oil temperatures fall due to lack of combustion (the hidden OBD menu can show this on the 2-series).
01-04-2019, 07:45 AM | #6 |
244
Rep 527
aerobod
you are correct, I proved this to myself last year when going west out of the rockies. Reset my trip meter at the top and coasted in gear for many miles. The mpg read 99 because that was the highest it could display but it calculated to a higher number as implied by displaying 99 for several miles of normal driving at the bottom. OTOH, when driving on relatively flat roads, coasting in gear slows the car quicker than coasting in N(neutral) so more speed is needed prior to coasting. The best choice depends on the situation. Most often I use N when traffic or a light tells me to stop soon. Since I will be sitting in N at the stop it makes sense to get there early and just coast up. |
01-04-2019, 08:32 AM | #7 | |
354
Rep 407
01-04-2019, 11:16 AM | #8 | |
43
Rep 121
01-04-2019, 05:58 PM | #9 |
Car Geek
3626
Rep 3,594
01-04-2019, 06:04 PM | #10 | |
4654
Rep 6,033
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
MichaelL41.50 |
01-05-2019, 05:35 PM | #11 |
433
Rep 442
If six is too many, having 8 speeds in the auto is way too many. It sometimes seems excessive just how many times it shifts getting up to speed. The shifts are quick and accurate, but it's still a lot of them. (Sometimes I even miss the CVT in my last car.)
I almost never use manual mode on the street, because it takes too many clicks to keep going up and down. Especially downshifting for a corner. Easier to let the auto skip gears all by itself. Track is a different story, where I'm always manual mode. But I'm only using 3-4 different gears, and it's easier to keep on top of it. The quick shifts are super nice, and I will often pop down a gear for a slower spot where it wouldn't be worth the effort with the manual, and stay at higher revs. |
01-05-2019, 05:50 PM | #12 |
5556
Rep 5,372
The 8at has ideal gearing for max acceleration and also mpg. The first three gears are key to why it's quicker than the 6mt. 2nd gear on the 6mt is good to around 72mph and 3rd to 103mph which is a bit too long for the power produced. I'd prefer 2nd to go to low 60s max and 3rd to 90-95mph. The 6mt would be a couple ticks quicker to 60mph and in the 1/4 mile plus the car would feel a lot quicker.
01-06-2019, 01:42 PM | #13 |
244
Rep 527
01-07-2019, 02:04 PM | #14 |
17
Rep 52
I tried many times to like manual mode, but ultimately kept coming back to that same conclusion. It just never felt fun or rewarding.
