12-29-2018, 05:59 AM | #1 |
244
Rep 527
What value Octane?
2017 230i with no mods
Is designed to run on 89 octane. If it is run on lower octane it protects itself from preignition by retarding the timing, reducing power. So if it is run on higher octane does it advance the timing and produce more power? Of course there is more to it than just octane and power, but without thread jacking please, what about the octane/power question? |
12-29-2018, 06:23 AM | #2 |
msej449
514
Rep 717
Drives: M235i Convertible +LSD 2016
Over here in the UK, BP and Shell offer a 'super' car fuel that's 98-99 UK Octane (92-93 US Octane). I get Shell V-Power nitro+ mainly for the detergent cleaning additives, as opposed to any performance gain. As I'm keeping my M235i Convertible for a few years, and I don't do a high mileage, I'm happy to pay the premium if it does anything to help longer-term engine health. I'd say that subjectively, I've not noticed a significant difference in performance between the lower and higher octane fuels in driving on public roads, so if it was a lease car I was handing back after, say, 3 years, I probably wouldn't bother paying the extra for the V-Power.
2016 M235i Convertible Estoril Blue & Oyster
2023 Peugeot e-208 GT (electric) |
12-29-2018, 07:55 AM | #3 |
109
Rep 278
Drives: 2018 230i xdrive convertible
My wife and I leased about 10 bmws throughout the years. I religiously put 93 octane in my cars even though it requires 89. My wife puts the cheapest brand and octane here which is 87 in her cars. I honestly cannot tell the difference in performance between the two octanes I don't even hear any engine knocking noise as they state might happen with 87.
I will still use 93 regardless. We only kept our cars for three years so I cannot comment on the longevity of lower octane on the engine. I would love if someone can explain this in detail. |
12-29-2018, 09:21 AM | #4 |
3848
Rep 2,873
This has really been covered to death in several other forums, complete with very detailed tech info; search function is your friend. Summary is something like 'it probably won't seriously hurt engine to run lower than recommended octane, but computer will pull boost/timing so you lose some power'. Less info and more mixed opinions on benefits of higher-than-recc'd octane in stock config (clearly beneficial for tunes); no idea if a 230 can use extra octane, but possible that midrange power would improve. Using a 'Top Tier' gasoline seems to be the most meaningful part of this, since the improved additives likely do make a difference long term; and using at least the recommended octane, since the potential for engine damage would overwhelm any potential savings.
12-29-2018, 09:52 AM | #5 | |
605
Rep 970
12-29-2018, 11:15 AM | #6 |
201
Rep 296
I almost always use top tier and try to stick to Shell v power nitro.
Recently I was in a hurry and filled up with Kroger 93 octane. There was a noticeable difference in responsiveness and power. I almost thought there was something wrong with my dinan tune. I also considered maybe I didn't get true 93 octane. Next tank I went back to Shell 93 and the power felt normal again. |
12-29-2018, 11:34 AM | #7 |
1655
Rep 1,237
Drives: M2 Competition
Stock DME of BMW's cannot sense anything more than 98ROZ. If you put in V-Power (100ROZ) then it will not give youe more power than the 98ROZ fuel, but you'll have cleaner combustion and the additives will help the motors longevity.
Personally i did V-Power 100 for over 12years in my E46 330Ci. It had a custom tune which could actually sense the 100 octane and make a something out of it. In my M2 Competition also only V-Power 100 plus 30ml of Payback's Fuel Optimiser each fill.
12-29-2018, 11:36 AM | #8 |
593
Rep 1,219
Drives: 2015 M235ix
With modern engines, lower octane will not induce knock, but the fuel management system will dial back the settings and you are likely to get worse performance and mileage. The savings from the lower price will then be offset by a combination of lower power and more fuel consumption. Keep it at 93. 91 will also work well, but hard to get in the NYC area.
12-29-2018, 07:00 PM | #9 |
374
Rep 520
I noticed the difference in power output, responsiveness and engine noise between 95 RON and 100 RON in my E46. 95 was fine but the engine just sounded happier and bigger-chested with the rocket fuel, and returned 5% better gasmileage.
In a 230i, not much difference. I think it's there, but I may just be convincing myself. It's hard to go near full throttle even with this car in gridlock, 20 mph traffic, the plethora of instant and average speed cameras, the other 38m idiots on the road, etc. Joining a (camera-monitored) motorway is about the only time you can do it, but flat out from 40-70 mph the difference caused by the fuels is going to be a long way sub 0.1 sec for that increment, which takes around 3 sec. |
12-31-2018, 06:30 AM | #10 |
M6GCComp, Porsche Cayman S PDK, Peug 208 GT1 BPS
512
Rep 1,280
Costco premium diesel makes significant difference to the performance of 520d especially at the mid range mph. The difference is night and day.
Acceleration is heavenly
12-31-2018, 09:20 AM | #11 |
35
Rep 67
The OP asked this question: "So if it is run on higher octane does it advance the timing and produce more power? "
The answer is No. Unless: the tune allows it and I doubt it does. It would mean the tune wants the higher octain and is always dialing it back to compensate. There "may" be ion knock sensing (ala Harley Davidson) that will sense impending knock and retard the timing for a few milliseconds....this you can feel. In my opinion, running higher octane fuel where not required will result in more combustion chamber deposits. You should run the lowest octane fuel you motor is designed (and tuned) to run on. |
12-31-2018, 09:33 AM | #12 |
4413
Rep 3,497
Do you know which octane that is for the six-cylinder 2 series cars - 91 or 93?
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
12-31-2018, 12:35 PM | #14 |
593
Rep 1,219
Drives: 2015 M235ix
93 cannot harm an engine designed to run on 91. In most markets, either 91 or 93 is available, not both. Use the fuel that is available in your area.
12-31-2018, 07:46 PM | #15 |
4413
Rep 3,497
Thanks - I see that I've got the same sticker on my fuel door. I've put Shell V-Power NiTRO+ 93 octane in the car since I got it.
12-31-2018, 10:02 PM | #17 | |
29
Rep 49
https://www.consumerreports.org/car-...h-extra-price/ |
01-01-2019, 11:29 AM | #18 | |
3848
Rep 2,873
You are probably better off adding a routine cleaning rather than occasional high-test, unless it is explicitly a better additive package, like for VPower (I use Techron every 5k; can't get Shell locally). |
01-01-2019, 12:02 PM | #19 | |
4654
Rep 6,031
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
Maynard3848.00 |
01-01-2019, 02:33 PM | #20 | ||
4413
Rep 3,497
What information have you come across regarding its effect upon the engine oil? Causing premature engine oil degradation is the last I want to see happen. As it is, I've used the BMW-branded product once - that was at 650 miles before an oil change.
01-01-2019, 02:43 PM | #21 | |
4654
Rep 6,031
With a Top Tier fuel, with that high level detergent package, every 3k miles seems excessive based on what I've learned. In the absence of Chevron fuel, with small doses of Techron already blended in, I am using Techron once per oil change, and timing it to very empty (reserve light on) and reflll the tank before the oil service visit. I do exclusively use Top Tier fuel, such as Costco, which exceeds the standard significantly.
01-01-2019, 05:29 PM | #22 |
225
Rep 610
The BMW stuff is rebranded Techron.
The Techron comes in different concentrations in the same size bottle. So pay attention to that. Techron is good stuff, used correctly you shouldn't have oil contamination problems. Use the correct amount for your tank and don't use too often. If you really want to make sure the fuel system is clean, double the concentration and run that out right before an oil change. |
