12-24-2018, 11:38 PM | #1 |
Alpine White M2
Rep 1
Drives: BMW M2
Should I disconnect M2 Battery for 3 weeks?
I need to leave the car parked for 3 weeks.
This is a standard BMW M2 2016. I cannot use battery tender because no power is nearby. Should I disconnect my car's battery for that period? |
12-25-2018, 02:16 AM | #3 |
230
Rep 254
i have left my dd m2 several times for 3 weeks at a time. i have not noticed anything negative not being on a tender or disconnected.
earlier this year i had to leave it for 6 weeks and got a battery tender. i plan on using the battery tender from now on for those multiple week business trips only because i have it and its extremely easy for me to set it up. |
12-25-2018, 07:37 AM | #4 |
401
Rep 580
Drives: 2018 M2
I think I read somewhere that the car uses less battery when it is locked...so you might want to lock it.
12-25-2018, 08:17 AM | #5 |
2432
Rep 2,526
3 weeks is nothing. What are you concerned with?
heavyD^23688.50 AndrewC198910932.50 |
12-25-2018, 10:59 AM | #7 |
331
Rep 425
3 weeks
the battery will be low at 3 weeks. i've been running the OEM battery charger every 3-4 weeks if it has been sitting idle.
when I plug it in after 3 weeks it will show 2/5 on the battery meter and take about 24 hours to bring it back up to 5/5. this thread just reminded me that i just passed the 3 week mark and i'm going to go plug it in now. |
12-25-2018, 11:31 AM | #9 |
756
Rep 2,149
Depends on your climate and the condition of the battery. If it's gonna be above 45 fahrenheit or so, I think it will be fine.
12-25-2018, 11:32 AM | #10 | |
331
Rep 425
starting
as mentioned above, I just ran down to the garage and plugged in the BMW charger on mine. it has been sitting indoors for 25 days without being started and the charger registered 2/5. |
12-25-2018, 02:50 PM | #11 | |
359
Rep 427
Over 18 months of ownership so far probably been away for long trips at least 10 times. |
2+3=5285.00 |
12-25-2018, 03:29 PM | #12 |
2315
Rep 4,341
Yes! Even if it starts it will be low and being low is not good for the battery. You will hear people say all sorts of stuff. I ran my car low on oil for years no problem. That doesn't mean you aren't taking 2 years off the life of the engine in the end. Batteries are happy charged. They are unhappy uncharged. The better choice of you can't trickle it is simply unplug it. So easy to do the right thing. Good luck.
12-25-2018, 10:40 PM | #13 |
7268
Rep 7,438
Like everyone has said before I have also left my car for 2 weeks without any battery issues. I had it sit for 2 months (doors not locked) without any issues, car did say battery was low when I put it in acessory mode but it still started fine.
GSound0.00 |
12-26-2018, 12:07 AM | #15 |
7268
Rep 7,438
Yeah in a period that long I'd recommend either intermittent starting, if it's not possible unplug the battery or use a battery tender.
I don't think it'll last that long especially if the alarm system is on. It might be able to last that period time and enter accessory mode but it may not have enough power to start the engine. |
12-26-2018, 12:28 PM | #16 |
88
Rep 115
I tender mine for more than 3 weeks. the idle power kills it.
the easiest way to know the battery is low, is if your start stop engine feature is NOT working as quick as before. with a fully fresh charged battery the car shuts down quickly on every stop.
2018 M2 6MT
12-26-2018, 01:05 PM | #17 |
7268
Rep 7,438
The easiest way would actually be a multimeter. Then the car telling you it's low on the dash.
12-26-2018, 01:17 PM | #19 |
7268
Rep 7,438
You certainly can test a battery with a multimeter, sub 12 volts means the battery is really low and likely won't be sufficient to crank the car. Nearing 12 volts means it's getting low and some features like auto start stop, or prolonged useage if the radio in accessory mode may be compromised.
12-27-2018, 02:29 AM | #20 |
1622
Rep 3,402
It will be fine, just left mine for 3 unplanned weeks and it was not an issue. I normally put it on the tender though. If your just doing it for one 3 week period I don't see an issue, if you are driving the car less often than not that might be a different matter.
12-27-2018, 02:50 AM | #21 | |
7268
Rep 7,438
If possible leave the car without the alarm system on and doors unlocked to prevent any unnecessary battery drain (little alarm light), and before you store it drive it hard to fully charge the battery. |
