12-20-2018, 06:46 PM | #1 |
466
Rep 716
Car jerking after sitting for a while (6MT)
Whenever I let my car sit for a couple weeks, it jerks/bucks in 1st and 2nd gear when I first start it up. After driving a short distance it goes back to normal and I can shift smoothly.
It never stalls out or anything, it just shakes around a lot and makes it look like I'm driving stick for the first time, no matter how slowly I let off the clutch. The jerking happens once I've let off the clutch completely and start accelerating. Today it was much worse than normal. Very rainy/wet outside not sure if it might have something to do with the moisture. Any ideas on what I should check? Anyone else have this issue? |
12-21-2018, 10:44 AM | #2 |
38
Rep 172
Where do you live? I sometimes get this when the temperatures drop significantly. It goes away for me when car warms up after a few mins.
Wagner Competition Intercooler, ER Chargepipe, Fabspeed Catted Downpipe, Bootmod3 OTS Stage 2 93 oct
donkey465.50 |
12-21-2018, 11:43 AM | #3 |
104
Rep 328
Drives: 2013 335i, ‘08 328i, ‘03 316ti
How many miles do you have on the car? Maybe changing the transmission oil could be beneficial. Pretty cheap at an Indy, under $200. You could also do it yourself, not nearly as involved as for an automatic. You could also have Blackstone do an oil analysis on the old transmission oil.
12-21-2018, 12:02 PM | #4 |
99
Rep 132
Sounds like I have the same issue. the clutch chatters a bit at the end of engagement. But mine seems more persistent than yours. It’s like half the time.
There’s several possible causes and none of them are easy to diagnose or repair.https://www.clutchdoctor.com/causes-...clutch-chatter I don’t see how the tranny oil could have any effect on this. |
12-21-2018, 12:09 PM | #5 | |||
466
Rep 716
12-21-2018, 01:55 PM | #6 |
5571
Rep 5,381
Humidity, cold friction clutch material, and the friction material grabbing on material embedded on the flywheel can result in this behavior. There's not much you can do about it until the clutch material warms a bit. My M235 will do it occasionally too and it's definitely more prevalent when it's humid out.
Sometimes I'll intentionally slip the clutch a lot in 1st and it will improve and smoothen clutch engagement.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
donkey465.50 |
12-21-2018, 04:11 PM | #7 | |
99
Rep 132
donkey465.50 |
12-21-2018, 05:29 PM | #8 |
2001
Rep 2,499
Happens to me too but only in first gear. It helps to warm the car up for about a minute before driving off. Mine only seems to do that when the engine is cold.
Do you by chance have a tune? |
12-22-2018, 10:31 AM | #9 |
466
Rep 716
Nope not tuned (yet anyway). I guess this is just normal, made worse by the fact I don't drive my car very often. I'll try just warming the car up before I go and slip 1st a bit to see if that helps.
12-23-2018, 02:46 PM | #11 |
101
Rep 337
Out of interest how often do you drive the car?
With older cars, this used to be a common problem with rarely driven MT's. Clutch plates are made of different stuff now, but back then it wasn't uncommon for a car not driven for several weeks to suffer clutch plate weld - caused by interaction between the materials. I'm sure even a modern car will have some reaction if left for long enough - it sounds like in your case, it's very minimal and a little clutch usage sorts it out. If you think of it in terms of brake feel after a period unused, it makes more sense. I'm sure you also notice a little inconsistency in brake feel until they have been used a few times and warmed up. Problem with clutches is, they're a really crude technology and haven't been able to evolve to the point they're as infallible as most of the rest of a modern car. The difference in a clutch that feels too soft or too abrupt is minute in mechanical terms, so it's not surprising that atmospheric conditions and/or a period of rest can make it feel noticeably different. Not that many years ago cars used to go through all sorts of various moods and maladies until warmed up |
donkey465.50 |
12-23-2018, 04:00 PM | #12 | |
466
Rep 716
12-23-2018, 04:09 PM | #13 | |
101
Rep 337
I think all you are encountering here is one of many the many common niggles car collectors have to deal with as they can't drive them all everyday - but they kinda need regular driving to stay in top form each time you set off. I wouldn't lose any sleep - I can say from experience that I would expect this from any car not driven frequently. |
donkey465.50 |
02-15-2019, 09:15 AM | #14 |
404
Rep 808
Just posting this to mention that I get this a lot as well. Seems to be somewhat random but related to a few factors. Cold weather for sure, but it sometimes happens in warm weather as well. Mainly it occurs when I've been driving highway for some time and then get back into the city and every first gear launch is rough unless I slip the clutch substantially.
It's a terrible feeling because I'm sure it's not great for the car and also makes the driver feel like it's his first time driving stick... my clutch is due for a replacement so next fall I'm going to do the 335is clutch and new dual mass flywheel. Hopefully this rectifies the problem. |
donkey465.50 |
02-15-2019, 02:19 PM | #15 |
95
Rep 279
I had this exact issue and while it sounds weird, a new battery fixed it.
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
donkey465.50 |
02-15-2019, 11:18 PM | #16 |
2JZ-GTE
3064
Rep 4,010
Mine chatters on engagement. If you slip it longer it chatters more. Almost like a vibration. BMW will tell you it's perfectly normal and will refuse to fix it
02-18-2019, 09:41 AM | #17 | |
466
Rep 716
I'll report back here if that fixes it for me too |
03-18-2019, 06:58 PM | #18 | |
466
Rep 716
I guess my battery was giving me just enough juice to get going, but not enough to do so smoothly. Mystery solved! Thanks for the heads up. |
03-18-2019, 07:16 PM | #20 | |
Rep 36
03-19-2019, 03:46 AM | #21 | ||
404
Rep 808
But yea if you can get a clutch replacement under warranty that would be ideal |
03-19-2019, 07:46 AM | #22 | |
Rep 36
But yeah, it only happens after driving longer distances, which is not too often for me. So if warranty does not cover it, I'll live with it for now. I got a quote for clutch replacement at $1,100 + tx. for labour and parts (OEM) (but no new flywheel), which seems quite reasonable. |
Tags |
banana, cookie monster, poop |
