BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Map Update... how long?
      12-14-2018, 10:17 AM   #1
Greyfox
Greyfox's Avatar
1208
Drives: 2007 328xi E91 - 330k+ (miles)
I just finished up the retrofit in my car and have figured out that the maps are from 2011. I double checked and I have the circle with a check mark in the lower left corner of the map and I believe that means I can update the maps via the USB port in the glove box.
I've pulled down the 2019 NA Map update and am in the process of acquiring a 32gb usb to put it on. I've also pulled the 1b hex from the unit and ran it through the fsc generator and have an update code.
But I read somewhere that this takes a while to update (stands to reason since you can't process 27gb of data into an IDE drive but so fast).
But how long does it take? I generally have a 5 hour commute on Monday mornings and was wondering if it will update while I'm driving?
      12-14-2018, 11:50 AM   #2
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
30 or so minutes if nothing goes to sleep. If sleep happens, it picks up where it left off. So doing it on your drive is not a bad idea.
Greyfox1207.50
      12-14-2018, 01:36 PM   #3
IllSic_Design
IllSic_Design's Avatar
2124
Drives: 09 E92 335i
I updated to 2018-1 last year and just did 2019-1 a few weeks ago. Each time it took about 55 minutes give or take 5-10 min. It's a little quicker with the 1 flash drive version.
Greyfox1207.50
      12-14-2018, 01:59 PM   #4
tcphoto
tcphoto's Avatar
3537
Drives: E92 335i 6MT Coupe
I bought my E92 two years ago and updated from Maps '09 to '17 with one flash drive and it took about an hour.
Greyfox1207.50
      12-14-2018, 02:49 PM   #5
UncleShrek
89
Drives: 2011 BMW 328i
Where does one get this 'flash'??
I seriously need an update
      12-14-2018, 04:01 PM   #6
Greyfox
Greyfox's Avatar
1208
umm.... on the front page of this board or searching on a certain automotive technology board?
