12-13-2018, 10:56 AM | #1 |
967
Rep 2,655
BMW Update UPD05081
BMW update UPD05081 available for is '14 3 series owners. Not sure what the changes are.
https://www.bmw.com/en/footer/software-updates.html Edit - Looks like the PDF states "Improves Connected Drive features".
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
12-13-2018, 11:44 AM | #2 | |
725
Rep 1,615
Nelson@BimmerTech I have the 6WB cluster. Would this update would wipe out that coding on the cluster? If so, how much to get the cluster recoded after this update? I'm having too many issues with my Pixel 2 and Bluetooth connections ATM so it might be worth the "cost of admission". EDIT: Adding release notes for others: UPD05081 - Hands-free kit with USB audio interface (optional equipment, code 6NH) - Mobile phone preparation Bluetooth connectivity with USB audio interface (optional equipment, code 6NK) - Mobile phone preparation Bluetooth connectivity with USB audio interface including BMW Assist (optional equipment, code 6NL) - ConnectedDrive Services (optional equipment, code 6AK) - Intelligent emergency calling (optional equipment, code 6AC) - Convenience telephony with extended smartphone connectivity (optional equipment, code 6NS) - Apps (optional equipment, code 6NR)
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? Last edited by jeffc83; 12-13-2018 at 11:47 AM.. Reason: Added more info |
12-13-2018, 11:56 AM | #3 |
105
Rep 219
I did the update the other night. Took 3 minutes. I don't have the SWB cluster but I have a couple things coded in mine such as the M Performance logo greeting etc. None of that changed. I beleive it only updates the iDrive software. I haven't noticed anything "new" either.
12-13-2018, 03:01 PM | #6 |
66
Rep 204
Drives: 2016 428i GC Alpine White
Can you share the UPD05081.PDF if you downloaded it? I cannot get it. Thanks!
2016 428i GC
12-13-2018, 03:48 PM | #7 | |
967
Rep 2,655
12-14-2018, 06:52 PM | #8 |
881
Rep 1,697
Drives: 2014 428i and 2018 X5
Updated mine today... I don't notice any difference / changes.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
12-14-2018, 06:58 PM | #9 |
967
Rep 2,655
I did as well. No noticeable difference.
12-15-2018, 12:13 PM | #10 | |
188
Rep 1,247
I've tried various cables and all do the same. |
12-15-2018, 02:55 PM | #11 | |
18
Rep 62
1) Cant read my text messages on idrive anymore 2) Issues with streaming over USB - will work then randomly stop working and wont reconnect even though its charging fine. Frequently displays "you can only use one device at a time" - or something similar on the phone 3) Wont connect over bluetooth to stream music randomly even though the phone is connected fine. And unfortunately, all three issues persist even after the update. Its possible that the update was in anticipation of a new IOS release.. |
12-15-2018, 03:28 PM | #12 |
353
Rep 1,245
12-15-2018, 06:24 PM | #13 |
66
Rep 204
Thanks Wilbur_the_goose. Indeed, seems like the BMW website prefers IE or in my case Edge better than Chrome.
2016 428i GC
12-15-2018, 06:30 PM | #14 |
2467
Rep 5,457
Drives: F30
Can someone please post a quick step by step on how to load this update into iDrive?
12-15-2018, 08:16 PM | #15 |
967
Rep 2,655
Format USB to FAT32 and drop the BIN file on the root of the drive. Plug in car then settings>software update>update software.
sspade2467.00 |
12-16-2018, 11:54 AM | #16 |
238
Rep 878
Just updated my car, was on
MN 003.003.001 TN 003.003.001 After MN 003.003.001 TN 003.255.080 HN 003.255.080 Unpaired and re paired my phone just in case but too early to see if I can notice any improvements or fixes. |
12-17-2018, 08:42 AM | #17 |
17
Rep 73
I have enhanced Bluetooth coded to my headunit. I presume any update will remove this. I do have BMW apps, but find that it rarely connects to my iPhone. The car sees the iPhone as an external device and I can play music from it, but it does not see the app functionality. I would be temped to update the headunit to see does this help with this, but don't wan to lose EBT.
Thanks |
12-17-2018, 08:45 AM | #18 | |
66
Rep 204
2016 428i GC
12-17-2018, 09:12 AM | #19 |
17
Rep 73
EBT isn't standard on my head unit, so just asking in case it defaults the headunit back to factory spec. I have read different reports on whether it would remove this coding.
12-19-2018, 12:15 AM | #21 |
22
Rep 75
Just checked and UPD05081 is available. Currently running UPD05074 which I loaded before I did some coding. Will I lose any of my coding by flashing this update?
I have EBT coded also, don't want to lose this or Connected Office. |
12-19-2018, 01:40 AM | #22 |
238
Rep 878
I didn’t lose any coding but it does reset the nav, media and telephone system so you lose any changes like equaliser settings which is a tad annoying as I had not written them down.
