Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Widest spacer for 2011 E90 328i w/285 rims square
      12-12-2018, 05:46 PM   #1
bluewater328
626
Drives: 2011 bluewater 328i LCI sedan
Just wanted to see if anyone had direct experience with the max spacer possible for this setup:
E90 328i LCI Sedan with 285 rims (square stance, 8" width IIRC) 225x47/17
I currently have on some 10mm Front and 15mm rear, and it honestly looks like the 15mm front and 20mm rear spacers could fit and fill out to the edge nicely.
Any insight anyone has would be helpful.
      12-12-2018, 07:06 PM   #2
Phyrexia
Resident Pedant
503
Drives: '15 335i 8AT
I'm in a similar boat with 10mm front / 12.5mm rear spacers and Style 285s.
I've read 12.5mm front / 18mm rear are ideal. Depending on your tastes, 15mm / 20mm would work too. It might poke out past the fender at that point unless you have a bunch of camber.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+
      12-13-2018, 10:58 AM   #3
CTinline-six
Hoonigan
CTinline-six's Avatar
6849
Drives: '09 328i, '98 Wrangler
Can you post pics of your current setup? I have these same wheels I will be putting on my 09 328 and want to get spacers.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park
Phyrexia502.50
      12-13-2018, 12:27 PM   #4
Donethat
Donethat's Avatar
339
Drives: 10’ 328 Msport w/ESS huffer
My nephew just bought a black 11’ 328e90 on style 285s, I plan on hooking him up with spacers. I have 10-12-15-18s, I’ll be fitting them around Christmas.
      12-13-2018, 04:15 PM   #5
Phyrexia
Resident Pedant
503
See attached (10mm front, 12.5mm rear, fresh alignment)
      12-13-2018, 06:40 PM   #6
CTinline-six
Hoonigan
6849
Looks good!
Phyrexia502.50
      12-14-2018, 05:36 PM   #7
bluewater328
626
Thanks for input. Starting to doubt the viability of 20mm in the rear now.
More input welcome -- again, esp if anyone has a current use (or similar width tire) example.
      12-15-2018, 01:44 AM   #8
Phyrexia
Resident Pedant
503
Bluewater, good sir, could you post some pics of the rear with the 15mm spacers?
      12-15-2018, 09:21 PM   #9
bluewater328
626
A few quick ones. Just seems like the space is there — esp since I'm not slammed.
