TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > TPM in a 12/06 built 335i????
      12-12-2018, 12:41 PM   #1
Nor_Cal_335i
Drives: EVO & 335i
Okay, so Im trying to help my buddy get rid of his TPM malfunction. Im familar with coding and was gonna code out the error for him. But After seeing his build date, I dont know why his car has TPM, and not FTM. I have owned 5 E90s and all the ones built before 9/07 should have FTM, not TPM.
Anyone ever see this before?
Current - '14 335i
Past -'11 X3 35i, '07 335i, '06 330i, '06 330i, '07 335i, '07 335i
      12-23-2018, 08:24 PM   #2
Nor_Cal_335i
Drives: EVO & 335i
Anyone?
Current - '14 335i
      12-24-2018, 03:37 AM   #3
Sensible_
529
Drives: 2008 E90
Originally Posted by Nor_Cal_335i View Post
Anyone?
What errors does he have? Are you sure it has TPMS? Look in the VO, is $2VB present?
If he had TPMS on a 2006 it must have been retrofitted.
      12-24-2018, 07:34 AM   #4
BOTUS
18
Drives: E90 335d
ABS sensor based detection was on 2007 cars, does his ABS work correctly? if so did he try putting the correct wheels and tyre sizes then resetting the system on the dash?
(30 second drive in a straight line, going slowly on smooth flat road - not that there of any of these in the UK)
      12-29-2018, 01:58 PM   #5
Nor_Cal_335i
Drives: EVO & 335i
Haven't pulled the actual codes outta the module. He lives like an hour from me. I was trying to figure it out before going over there. Ill check the codes though and check the VO.
Current - '14 335i
      12-29-2018, 05:21 PM   #6
Nor_Cal_335i
Drives: EVO & 335i
ABS is working fine and not throwing any codes.
Current - '14 335i
      01-19-2019, 07:44 AM   #7
Greyfox
Greyfox's Avatar
1208
Drives: 2007 328xi E91 - 330k+ (miles)
My E91 has a build date of March/April 2007.... I have TPMS.
