e90 frmv2 c08 help
12-08-2018, 04:29 AM | #1 |
Rep 24
e90 frmv2 c08 help
hi everyone i tried to make my drl with angel eyes today on my 2011 e90 with frm v2 c08
so i made the follow change VERHALTEN_DRL_TFL set to drl_s instead of drl_tfl_off and recoded it previously i have low beam as drl in auto position now it gone and no angel eyes as drl in 0 position and angel eyes in postion light flirk only with engine running i didn't figure out the problem that happened thanks in advance |
12-08-2018, 09:23 AM | #2 |
Save the manuals!
6022
Rep 6,751
There's a few other lines that need to be changed too if I recall. Search with NCSDummy for more DRL parameters.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
12-08-2018, 11:10 AM | #3 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
You'll need to leave the headlight switch in the auto position. Change TAGFAHRLICHT_ECE_1 --> aktiv and DRL_TFL_MIT_SML --> aktiv as well. See if that does the trick.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
12-08-2018, 11:47 AM | #4 |
Rep 24
i will try this but first i need to fix problem of the led angel eyes flickering when engine is runing it seems like the voltage is too low
is there any methode to reset configuration to original state i tried with the backup file that i made before but no luck by the way car is european spec with halogen headlights |
12-08-2018, 12:16 PM | #5 | |
Sua Sponte
1299
Rep 2,850
