12-06-2018, 09:40 PM | #2 | |
///M
6654
Rep 3,683
If you put 305 on the back the front needs to be 295 to be within 1.3% Circum. But 295 needs to be on 10" rim and your's are 9.5" You can put 285 front and 305 back on stock rims and that will push it up to 1.8% Some people are ok with 1.8% I prefer to be 1.3 or less
Life is too short...enjoy your life
///M |
M 4EVER191.00 Sam@ModeCarbon5731.00 |
12-06-2018, 10:17 PM | #3 | ||
122
Rep 179
12-07-2018, 05:31 AM | #4 | |||
///M
6654
Rep 3,683
You still need to switch the front rims one size down in diameter
///M |
12-07-2018, 08:48 AM | #5 |
153
Rep 427
Drives: 2019 M5 Competition
I don't have to worry about this until Spring, but I'm trying to figure out what I want to do here as well. I was running 305 rears on my M6, so ideally I'd like to go that wide (or wider) here, but the AWD limiting the diameter differences makes things tricky.....
12-07-2018, 09:13 AM | #6 | |
///M
6654
Rep 3,683
I can tell you what tire hight and rim width needs to be
///M |
12-07-2018, 09:26 AM | #7 | ||||
122
Rep 179
I'm trying to achieve maximum traction (using Mp4s) but stay in the acceptable xdrive tolerance. |
12-07-2018, 09:54 AM | #8 | |||||
///M
6654
Rep 3,683
Again you can put 305/35/20 back and 285/35/20 front that would be 1.8% I have seen people on this forum using this setup I like to stay below 1.3% I am going to post mine as soon as a decide what rims and offset I will go with
///M |
M 4EVER191.00 |
12-07-2018, 11:05 AM | #9 |
///M
6654
Rep 3,683
///M |
02-21-2019, 05:46 PM | #11 | |
2464
Rep 3,803
Front- 285/35/20 Rear- 295/35/20 Thanks |
02-21-2019, 06:27 PM | #12 | ||
///M
6654
Rep 3,683
///M |
Who's on first2464.00 M 4EVER191.00 |
02-22-2019, 06:50 AM | #13 | |||
2464
Rep 3,803
02-22-2019, 07:52 AM | #14 | ||||
///M
6654
Rep 3,683
///M |
Who's on first2464.00 |
02-22-2019, 08:54 AM | #15 | |
514
Rep 1,437
This is what I think I am going with as well. I really wanted a 305 rear but Michelin doesnt make a 305/35. Only a 305/30 or a 305/25. Id really like a more robust sidewall so I think Im going with a 295/35. I will give up .4 inch in tread width compared to a 305 but everything else falls into line.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
05-14-2019, 08:36 AM | #16 | ||||||
122
Rep 179
305/30/20 285/30/20 |
05-14-2019, 08:42 AM | #17 | |||||||
///M
6654
Rep 3,683
Stocks are off at 1.1% so differential are calibrated for that... in reality you are off only 0.7%
///M |
05-14-2019, 08:50 AM | #18 | ||||||||
122
Rep 179
05-14-2019, 11:04 AM | #20 |
960
Rep 1,051
According to this post you can use whatever tire size you like as long as you configure it via iDrive, has anyone done this yet?
https://f90.bimmerpost.com/forums/sh...0&postcount=11 |
JK-M561.00 |
05-18-2019, 05:31 PM | #21 |
153
Rep 427
That’s for the tpms not AWD differentials.
11-18-2022, 08:34 PM | #22 |
681
Rep 527
Miko, I hate to bring this forum back to life, but I just picked up my F90 M5 Comp. It has the 789M wheels. I want to run a 305/30/20 in the rear. Is this possible with a stock 275/35/20 up front, without causing differential problems? Sorry, I could not find this request above.
Or is it possible to run a 265/35/20 up front and a 275/35/20 in the rear? Asking based on tire sizes that my company has in stock... Thanks! |
