BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    HRE Wheels | Track Ready F90 M5 with HRE RC104's in Satin Gold!
      12-06-2018, 01:02 PM   #1
HRE_Wheels
HRE_Wheels's Avatar
2118
Drives: F80 M3 6MT
Here we've got a lovely F90 M5 which will see some track time for sure! For his Track Beast we wanted to get a set of RC104's on there to help lower the weight significantly and to also give it some updated looks!
20x10 fronts with 285/35/20 tires
20x11 rears with 295/35/20 tires
HRE RC104 - Satin Gold Finish
Thanks for taking a look!
      12-07-2018, 06:49 AM   #2
onfireX5
3619
Drives: F90M5,F85X5M
Killer wheel.
      12-07-2018, 06:50 AM   #3
onfireX5
3619
How much weight did it drop ?
      12-07-2018, 10:00 AM   #4
HRE_Wheels
HRE_Wheels's Avatar
2118
Drives: F80 M3 6MT
I weighted the wheels before we released them to the customer, here are the weight figures as compared to OEM, it's quite impressive:
HRE RC104:
20x10 - 22.00lbs
20x11 - 23.20lbs
BMW OE Competition Wheel Weight
20x9.5 - 28.00lbs
20x10.5 - 29.50lbs
Weight info was taken from this post
HRE Weight Savings for RC104
Fronts - 6.00lbs per wheel saved - 12lbs in total up front
Rears - 6.30lbs per wheel saved - 12.6lbs in total on the rear
Total weight saved, 24.60lbs of unsprung weight.
For those of you who want to save even more, then these bad boys would do the trick, a set of R101 Lightweights in 20":
HRE Weight Savings for R101 Lightweight
Fronts - 9.8lbs per wheel saved - 19.60lbs in total up front
Rears - 10.7lbs per wheel saved - 21.40lbs in total on the rear
Total weight saved, 41.00lbs of unsprung weight.
      12-07-2018, 10:24 AM   #5
onfireX5
3619
20” cast oem front = 35lbs. Rear = 36lbs. That would be a 52lb savings in rotational weight with the HRE.
HRE_Wheels2118.00
      12-07-2018, 01:30 PM   #6
WheelsBoutique
WheelsBoutique's Avatar
1180
Drives: 2015 M4
Unbelievable weight savings with these. I think a Brushed Clear finish would bring out the design of the RC104's even more. I can't wait to get a few of these on some F90's.
Appreciate 2
      12-07-2018, 04:37 PM   #7
Miko M
///M
Miko M's Avatar
6654
Drives: 2020 M2C. 2020 X3M
Can you PM set off HRE RC104
Life is too short...enjoy your life
///M
      12-10-2018, 10:24 AM   #8
HRE_Wheels
HRE_Wheels's Avatar
2118
Drives: F80 M3 6MT
PM inbound!
      12-23-2018, 10:47 PM   #9
hybrid_eg
hybrid_eg's Avatar
852
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
What are offsets on r101’s?
      12-24-2018, 08:34 AM   #10
WheelsBoutique
1180
Drives: 2015 M4
There is a small range of offsets that can be used for the R101 Lightweights. Was there a specific F90 M5 that you had seen with these wheels where you wish to replicate the fitment from?
      12-24-2018, 11:58 AM   #11
hybrid_eg
hybrid_eg's Avatar
852
Post above shows the R101 from HRE showing widths and weight differences. What are the offsets that HRE plans on offering these in?
      12-24-2018, 12:30 PM   #12
WheelsBoutique
1180
Drives: 2015 M4
The ones shown weighted above were for our F90 client who was the very first to get the R101 LW's on an F90 M5. We've been building the R101 LW's for this vehicle at ET 23 & ET 29.
Feel free to email me directly if you'd like more information - David@WheelsBoutique.com
      01-03-2019, 03:21 PM   #13
MSPORTWORLD
MSPORTWORLD's Avatar
232
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Here's my RC104 w/tires vs OEM setup comparison.
Appreciate 2
      01-03-2019, 05:09 PM   #14
Viper7
36
Drives: 2014 F80 M3 Mineral Grey
So those pics are of the exact same OEM tires mounted on the slightly wider RC104 rims?
      01-03-2019, 11:33 PM   #15
MSPORTWORLD
232
It's actually a wider tire mounted on wider wheels than stock
Complete build can be tracked here:
https://f90.bimmerpost.com/forums/sh....php?t=1568373
      01-13-2019, 04:05 PM   #16
M5speed
70
Drives: 2020 BMW M5
The gold is an interesting look. Have you got any images showing the gold in more of a gloss finish or even the hre 540 with the gold/gloss lip?
      01-14-2019, 04:41 PM   #17
WheelsBoutique
1180
Drives: 2015 M4
Here's a good look at Gloss Gold on S101's. For the 540's I see a Brushed Gloss Gold done but not a Gloss Gold. I can share those images with you as well - David@WheelsBoutique.com
      01-14-2019, 04:58 PM   #18
Ever34
325
Drives: F90 M5
Those are vey nice. Wonder what a set satin bronze would look like on a donnington grey?
      01-14-2019, 06:10 PM   #19
Viper7
36
I've got a question for all you wheel and tire gurus.
I want to go with 21" wheels but stick with the PS4S tires, rather than go back to PSS's.
That means I'll probably stick with a 275 tire on the front (same as OE width), but go to a wider 295 on the rear (given there is no 285/30/21 size for the PS4S).
Does this present any issues for the 4WD system etc? Since I've gone one size wider at the rear but stuck with OE at the front, and the diameter of the new tire combination is a slightly bigger difference between front and rear?
Anyone upgraded to the below sizes and have any feedback?
F:
21 x 9.5
275-30-21 Michelin PS4S
R:
21 x 11
295-30-21 Michelin PS4S
      01-15-2019, 01:47 PM   #20
HRE_Wheels
HRE_Wheels's Avatar
2118
Drives: F80 M3 6MT
F:
21 x 9.5
R:
21 x 11
Haven't set up an order like that yet but if you want to use those tires I can certainly accommodate and build you a 21x9.5 up front and the 21x11 we do normally on the rears for sure.
      01-15-2019, 08:07 PM   #21
M5speed
70
Drives: 2020 BMW M5
[SIZE="4"][COLOR="Red"]
[IMG]https://cdn.bmwblog.com/wp-content/u...1-Wheels-6.jpg[/IMG]
[/COLOR][/SIZE]
How much to put a set of these on layaway? Being three piece, Id figure them to be somewhat less than the mono-block ones.
Meaning how much are they?
      01-17-2019, 10:33 PM   #22
M5speed
70
Drives: 2020 BMW M5
How much for the wheels? Pm me thanks!
m5post
