BMW 5-Series (G30) Forum 2017+ BMW 5 Series (G30) General Discussions 12 volt power in trunk question
      12-01-2018, 10:22 PM   #1
LetsrollM550
LetsrollM550's Avatar
30
Drives: M550i
Is the 12 volt power in the trunk always on, or does it turn off like accessory mode when the car sleeps? How long does it take to actually go sleep? 2018 M550i, this is my first BMW still trying to get up to speed, car stereo shop today started to add a audio control lc2i and a alpine amp to drive new SWS subs to replace the pathetic HK subs, but they couldn't get the amp and lc2i to power up with speaker level inputs, when he ran a trigger wire to the rear 12 volt power everything worked, but amp would not power down as the key was in the car and it wouldn't go into sleep mode. Thanks, and yes I need a new stereo shop!
      12-03-2018, 06:35 AM   #2
TreyWaters
82
Drives: 2018 BMW M550i
The trunk power outlet will power down once the car powers down (ie., when you lock the car), and then powers up when the car powers up (or, when you unlock the car).
________________________________________
2018 BMW M550i - Med Blue / Black / 668M wheels [ZCW, ZDA, ZDB, ZDH, ZEC, ZLS, ZPK, 416, 5DV, 6WB] (ED 9/18/2017; PCD 11/30/2018)
2009 Acura MDX Tech - Silver / Grey (2009-2017)
2003 BMW Z4 3.0i - Silver / Red (2006-2009)
      12-03-2018, 08:29 PM   #3
DBO
Australia
159
Drives: G30 540i SDrive (MPPSK+Mods)
If you want constant power from the trunk it couldn't be easier - just take a line from the main battery (fused of course). If you need switched ACC power then that's also available in the fuse panel in the trunk.
5post
