Downpipe install
11-29-2018, 08:09 AM | #1 |
12
Rep 58
Downpipe install
I got some downpipes i need to re install on my car anyone know of a good spot in the Bay Area to get them done at a couple shops told me i have to bring the car in a trailer and take it out in a trailer cause they are catless
11-29-2018, 11:19 AM | #2 |
33
Rep 48
Drives: 2008 BMW 335i
Do it yourself. It's not really that hard. You trying to pass smog? I take mine off every 2 years for a week to pass smog.
11-29-2018, 01:21 PM | #3 |
16
Rep 72
I've had luck using the DP fix, and not taking my pipes off. You probably won't find a shop to do this for you, because its illegal to remove cats.
I would try to convince someone here to help you out, or just learn to do it yourself if you have some basic tool skills. And tools! At the very least, you'll need a jack, a couple of jack stands, and some balls to be able to get under the car, on your back, to do this job. As well, remember that when its smog time, you will either need to put the cats back on, or locate a DP fix, which is a little electronic module, and install that/mess with it to make things work and look like the cats are still on to the smog machine.
JB4, DPs, Style 313 wheels, M-Sport front bumper, Inlets, DCI
11-29-2018, 03:59 PM | #4 |
202
Rep 649
If your car is RWD it's pretty easy. If it's AWD it's not too bad but not fun either.
17 M3 Comp
Unknown_Car447.00 |
11-30-2018, 05:44 AM | #6 |
1903
Rep 6,968
If the car has seen Salt or harsh winters like in the mid-west or NE, then it will be a major PITA getting the OEM cats off. However, if that's not the case, I agree with the above posters, shouldn't be too bad on 4 jack-stands with the right set of tools. Just make sure you get replacement gaskets & bolts. Maybe get some Nickel based anti-seize for the exhaust bolts & V clamps on the turbo to down pipe connection. That will make getting them off next tine a whole lot easier.
01-04-2019, 12:23 PM | #7 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
How did it go?
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
01-04-2019, 02:25 PM | #8 |
20
Rep 68
I dont know about the OP, but I installed some DPs on the New years day. Pain in the ass to get the V band clamps to set perfect. I got a couple question for some people though, after I put on the Downpipes I could feel the idle throughout the car a lot more making me think I might need to go under and re adjust or something. Is this normal? Also I knew I would be able to hear my turbos more, but The new turbo noise is high pitched and almost like a whistle, is that normal? I Have Newer OEM turbos with about 10,000 miles on them so I dont think its anything with the turbos. What you guys think?
01-04-2019, 03:05 PM | #9 | |
574
Rep 940
01-04-2019, 03:14 PM | #10 | |
449
Rep 1,327
01-04-2019, 03:26 PM | #11 |
574
Rep 940
01-04-2019, 03:28 PM | #12 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
01-04-2019, 04:17 PM | #13 |
4276
Rep 9,206
That is true, however it might cause issue lining them up with with the exhaust. When done this way they either pull or push on the turbo housing. What I do is place a washer between engine mount and engine to space them up. Essentially you are raising the engine few millimeters which is usually enough to clear any interference between pipes and subframe. Sometimes I even replace the side bolt on the engine mount bracket. All depends from the pipes.
01-04-2019, 05:40 PM | #15 |
4276
Rep 9,206
Silent9n54573.50 |
01-05-2019, 08:37 AM | #16 |
Guest
Rep n/a
Drives:
If they have little/no experience with the N54 or this platform, all that experience means nothing when it comes to solving your problem.
01-07-2019, 07:41 AM | #17 |
20
Rep 68
https://photos.app.goo.gl/1uXrSuHE1UJERKNv7
For my install, I think it may be the Down pipe Flanges touching each other. I will attach a pic of what I'm am talking about. I should be able to adjust them slightly so they don't touch?? |
01-07-2019, 08:00 AM | #18 | |
Sua Sponte
1299
Rep 2,850
DM_e9219.50 |
01-07-2019, 08:09 AM | #19 | |
20
Rep 68
01-08-2019, 07:51 PM | #20 |
13
Rep 33
Drives: BMW E90 335i
I just had a shop install downpipes on my e90 yesterday... well safe to say they messed up.
Took it for a drive, the turbos are rattling like crazy! (brand new stock turbos installed by them 3 months ago) and only making 2psi boost... guessing the vband clamp bolt is obstructing the wastegate arm or something. They're looking tomorrow under warranty. They managed to get 10mm clearance with the downpipe to the body luckily Asked them to tighten the rods too as i had turbo rattle accelerating before the install and they said they are tight as ever with no play... think i need a new shop haha
2006 E90 335i Graphite Grey M-Sport Sedan / 155k Kms / AR-Design catless DPs / VRSF 7" intercooler & chargepipe / BMS DCI / M3 Control Arms / Bilstein Suspension / MHD Stage 1+ 93OCT
Jaronbwall284.50 |
01-08-2019, 08:18 PM | #21 |
4276
Rep 9,206
Austins all OEM designed turbos will rattle even brand new and downpipes will make that more obvious since catalytic converters will muffle the rattle. I have posted videos on here to support this. Regarding not making boost post downpipes installation could be an interference as you said or incidentally disconnected vacuum line. I hope it will be a quick fix.
