11-28-2018, 12:02 PM | #1 |
3618
Rep 4,532
Dragy tested the RaceChip vs Stock 100-200kph
Disclaimer : My physical elevation is 2100ft so you guys at sea level will be faster. All numbers at the same location with Dragy.
My M5 pure stock went 11.23 seconds in the 1/4 mile with a 7.37 seconds 100-200kph on that same pass. Added RaceChip and the 1/4 dropped to 10.86 and the 100-200kph dropped to 6.73 on that same pass. Did a back up 100-200kph only pass today and it went 6.69 seconds. So RaceChip decreased my 100-200 by 0.68 seconds. Interestingly, RaceChips own 100-200kph test was 6.88 stock and 6.22 with their chip added....a reduction of 0.66 seconds. So the Delta is consistent, but the Quartz Sat box they use must measure something differently than Dragy. My elevation isn't THAT much of a negative. Might have to retest with my VBox to see if it is different. But a 0.6x reduction either way is a WIN. Thanks to Ben r33_RGSport for a killer mod that's easy to install. |
11-28-2018, 12:32 PM | #2 | |
///M
6654
Rep 3,683
I noticed that slope is over 1% ( 1.35 % ) too which normally wouldn't be valid on dragy I believe it wouldn't make much off a difference if you would be just under 1%. I couldn't get below 7.35 sec. At 1030 elevation with RC, I believe winter tires must have been slipping just enough to cause the drop. I like the RC so far no problem already 1000mil on it
Life is too short...enjoy your life
///M |
r33_RGSport12965.00 |
11-28-2018, 12:54 PM | #3 | |
3618
Rep 4,532
11-28-2018, 12:55 PM | #4 |
3618
Rep 4,532
Gotta run them where you won’t go to jail at 130mph. Lol.
11-28-2018, 01:02 PM | #5 |
///M
6654
Rep 3,683
I know. Lol
I found close road that is just over 1/4 mil long and nothing but cornfield
///M |
11-28-2018, 02:15 PM | #6 | |
12965
Rep 18,712
Thank you guys for the credits and reviews. Should give credit to RaceChip's engineers too.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
F90BSM568.50 |
11-28-2018, 05:16 PM | #7 | |
///M
6654
Rep 3,683
I happened to drive around and in a middle of nowhere and I see a sign Dead End So I figured I go see how long the road is and it end up being more then a 1/4 mile....surrounded cornfield on each side Perfect spot to testing , nobody around for miles
///M |
11-28-2018, 08:36 PM | #8 |
19352
Rep 10,166
onfire ive been drinking lol so i cant read well, whats your trap speed on your best run in the 1/4?
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
11-28-2018, 09:49 PM | #9 |
3618
Rep 4,532
DA was 3400 feet ish on this pass...This was before the DME fully adapted to RaceChip.
11-28-2018, 09:56 PM | #10 |
3618
Rep 4,532
This was after the DME adapted....almost picked up 2mph in the 1/8th mile. Did not run it out to the 1/4 mile. Should be 3mph over the above post at 3400ft elevation.
Vic5519351.50 r33_RGSport12965.00 |
11-28-2018, 10:11 PM | #11 |
19352
Rep 10,166
damn so almost 130
11-29-2018, 09:11 AM | #12 |
3618
Rep 4,532
11-29-2018, 09:48 AM | #13 |
1716
Rep 1,909
Drives: 2023 M5C
Does the Dragy unit not measure 0-60mph times?
11-29-2018, 09:55 AM | #14 |
3618
Rep 4,532
11-29-2018, 11:37 AM | #15 |
1716
Rep 1,909
Drives: 2023 M5C
11-29-2018, 12:50 PM | #16 |
3618
Rep 4,532
Just for you.
11-29-2018, 08:31 PM | #17 |
3618
Rep 4,532
You made me curious so I had to make an "after" run since the DME has adapted today.
Could not use Launch Control since the road was wet. Just rolled into the throttle off idle. ET is off by a solid 0.30. LC will ad a bit more mph too when it drys up... RaceChip is a bad dude.... |
11-29-2018, 09:46 PM | #18 | |
19352
Rep 10,166
11-30-2018, 05:04 PM | #19 |
12965
Rep 18,712
12-01-2018, 02:35 PM | #20 |
19352
Rep 10,166
No actually Im very happy with RC but because I want more I need to figure stuff out
12-01-2018, 02:45 PM | #21 | |
12965
Rep 18,712
Got your springs already.
