Coby Wheel
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Cars for Sale > 2007 BMW e92 335i Coupe - Space Grey/Red - NJ - $12,500
      11-24-2018, 09:56 AM   #1
dustinsterk
dustinsterk's Avatar
Drives: 335i - MT
BIMMERPOST / Classifieds
Asking Price:
Sold
Item Interest
Price Drop -- 11K OBO.
New NJ Inspection. Bought another car and need this gone.
6 speed manual - 2007 BMW e92 335i coupe. I have owned the car for 1.5 years and put only 6K miles on it since (purchased from another member and the orig posting is here). Prior owner was in the military (texas car) and put all highway miles traveling to and from bases, currently has 162,xxx miles. Garage kept and the car is not my daily driver. Never sees the salt or winter roads.
Since my ownership I have completed all of the expensive and major maintenance including index 12 injectors, new valve cover and gasket, oil pan gasket, oil filter housing gasket, rear main seal and much more. Full maintenance log below. All of the major maintenance was completed by ZNM Auto in Pomton Lakes (matt@ZNMPerformance). Turbos and HPF pump replaced by BMW at 90k. Red leather and carbon fiber trim. Full bolt-ons including upgraded charge pipe, Tial BOV, upgraded FMIC and MHD tuned stage 1+. New tires, EBC yellowstuff brakes and stainless steel lines. Custom exhaust. All fluids flushed. NJ Inspection valid until 12/18. Clean title in hand.
Factory Options:
Adaptive Bi-xenon headlights
Logic 7 Premium Sound System w/ AUX
Fold-down rear seats
Premium Package:
Power, memory, lumbar 10-way adjustable seats
Coral Red Leather seats
Power Sunroof
Convenience Lighting
Sport Package:
Higher top speed limiter
Sports bucket seats w/ adjustable thigh support
Sports steering wheel
Secondary oil cooler mounted in front bumper
Bluetooth Phone
Exterior Mods:
Shaved model information (no ‘335i’ emblem on the rear trunk)
M-Sport Front Bumper and yellow fogs - 156k (replacement and repaint)
M-Sport Side Skirts
Black Grills
BMW High Kick Style Rear Spoiler
Carbon Exhaust diffuser
Carbon Fibre BMW Black/White Emblem Set (Hood, Trunk, Steering Wheel, Wheel Hubs)
Wheel Studs & Wheel Locks
18” Forgestar CF5’s
265/35ZR-18 SUMITOMO HTR Z III XL - 156k replacement
235/40ZR-18 SUMITOMO HTR Z III XL - 156k replacement
Performance Mods:
MHD Stage 1+FMIC Tune - 156k
Arm Motorsports Charge Pipe - 156k
Tial 50mm BOV and ¼” NPT tapped intake manifold vacuum port for BOV - 156k
5” stepped Arm Motorsports FMIC - 156k
BMS Oil Catch Can
Dual Cone CAI
Magnaflow Quad-Tip exhaust
Turner Motorsports Slotted Rotors and YellowStuff ECS F/R Brake Pads
Stainless Steel Brake Lines, Racing Brake Flush
HP Autowerks Koni Coilovers with Swift Springs (rears replaced -- see below)
Lighting and Interior Mods:
Carbon Di-Noc interior wrap
LCI Style LED Angel Eye Rings Retrofit
LCI LED Tail Lights Retrofit - 156k replacement
Headlight Restoration - Wet Sand and Polish/Protect - 156k
BimmerGeeks Pro-Cable K+DCAN ODB2 USB Cable / Installation in glove box with 90deg plug
BMW OEM All Weather Floor Mats
Coding Mods:
Coded out / disabled seatbelt arms/extenders
Coded out all LED light checks (warm/cold, voltage checks) for Angel eyes and rear taillights
Coded out TPMS (unplugged module remains in rear trunk above the battery)
Coded comfort access to eject key and unlock doors (when holding start button for 2 seconds)
Maintenance:
Oil change with BMW OEM Synthetic (6.5 liters, Mann Filters) - every 5k
Gear shift lever / AC bracket recall completed - 30k miles
Turbos and HPFP's were replaced with the new PN's - 80k miles
Alternator replacement - 115k
Upgraded 335is engine mounts replacement - 120k
Intake Walnut Blast - 120k
Headlight control unit module replacement - 125k
Xb35 headlight build replacement - 130k
LP Fuel Sensor / pipe upgrade - 156k
Full 6 cylinder BMW OEM Plug and Coil Packs replacement - 156k
Windshield Wiper Blades - Bosch Aerotwin - 156k
BMW Airbag recall replacement (drivers side) - 156k
Rear Windshield Molding - 157k
Oil Pan Gasket - 157k
Water Pump & Thermo + U-Hose / Upper Radiator & Exp. Tank Hose / Coolant Change - 157k
Serpentine belt & Tensioner - 157k
Power Steering Pump & Fluid Change - 157k
OFHG & Oil Cooler seal, o-rings in lines, Thermo Looming - 157k
Rear Main Seal Replacement - 157k
New Valve Cover, Gasket, Bolts Replacement - 157k
Rear Diff Reseal (RTV Black) and Fluid Change - 157k
Clutch and Flywheel - Visual Inspection when doing Rear Main Seal - Still looks great. - 157k
Synthetic Oil Change / Mann Filter - 157k
KYB Rear Shocks (Replaced Koni)- 157k
Both After CAT 02 sensors replaced (black and grey) - 157k
Cabin Air Filter Replacement (Mann Filter) - 157k
Two new key fobs / programmed / cut - (G Coding BMW) - 157k
New Battery/Recoding (Duralast Gold H8-DLG - 5 year warranty(1/28/2018)) - 157k
New Power Steering Reservoir and fluid flush again - 159k
YellowStuff ECS F/R Brake Pads, Stainless Steel Brake Lines, Racing Brake Flush - 159k
LED front turn signal upgrade - 159k
Index 12 injectors with new OEM seals and decouplers- 160k
R1 Concepts drilled and slotted rotors - 162k
Please PM if you are interested and I would be happy to answer any questions or show the car in person. Located in Bergen county (northern NJ).
2007 335i, 6MT, Space Gray/Coral Red, Magnaflow quad tip, CAI's, BOV/CP, FMIC, MHD Stage 1+, BMS Oil Can, Slotted Rotors and Pads, M-sport skirts/front bumper, Carbon interior/rear exhaust diffuser, LCI angle eyes & red tails,18" Forgestar CF5s, Coilovers/Swift springs
      11-27-2018, 05:00 PM   #2
dustinsterk
Drives: 335i - MT
BUMP
      12-11-2018, 04:18 PM   #3
dustinsterk
Drives: 335i - MT
BUMP
      12-13-2018, 11:13 AM   #4
Spyro235
260
Drives: '10 X5D, '04 330i ZHP
Not trying to start anything, but I think you're priced really, really high. There's a beautiful one owner e90 that just went up for 12.5k, and I bought my e90 rwd 6 speed, with premium/sport/winter packages, for 9k 2 years ago at 123k miles. I'm at 169k miles now and wouldn't expect more than 7-8k for my car. This car is modded, which most people associate with less valuable too, since it was more than likely driven harder.
Daily/ Tow: 2010 X5 35D - 326k, Deleted w/DUDMD Stage 2, Sutphin Trans tune, Comfort seat retrofit
Fun car: 2004 ZHP 6mt - 256k miles, z4m FCAB, stock. Drift car: 2001 330i for sale
      12-13-2018, 11:52 AM   #5
dustinsterk
Drives: 335i - MT
Thanks for the feedback. I still find it amazing how quickly these cars loose their value compared to other cars (Hondas for instance). If 7-8k is really the market price, I would rather just keep the car. I have thousands spent just in my recent maintenance under my ownership.
      01-07-2019, 11:34 AM   #6
Spyro235
260
Agreed. I'm about to list mine for sale, at 171k with no problems.... I'm going to likely list it at 10k and expect to lose some in negotiations.
      07-15-2019, 08:46 AM   #7
dustinsterk
Drives: 335i - MT
Bumping this due to price drop. Bought another car and now need this gone.
      09-25-2019, 07:38 PM   #8
dustinsterk
Drives: 335i - MT
Car is sold....for sales data I ended up selling it for $9,500. I will miss this car! Maybe one day I will own another N54, they are are blast to drive.
