Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > E91 325xi staggered rim and tire setup
      11-24-2018, 05:51 AM   #1
SparQ
Drives: E91 325Xi
Hi Guys,
I am driving E91 325xi 2006 USA.
I know there are some dependencies if you want to make a staggered setup on AWD car. However I found out in forums that for R18 I could go with 225/40 (front) and 255/35 (rear) tires and there should be no problems with AWD system - https://www.e90post.com/forums/showthread.php?t=1050762.
If someone has different experience please shout out!
Now I am looking for new set of rims for my mentioned tire type and I am not to sure what J and ET I should look for a wheel set to look and perform good. Would JR18 R18x8.5 ET 35 (front) and JR18 R18x9.5 ET 35 (back) fit n my case? What other options I could be looking at? Maybe you could drop specs of what staggered setups you are running? Thanks!
      11-24-2018, 06:04 AM   #2
E90Daily
Drives: 335i
Depending on what kind of setup you're doing. That's safe aswell. I'm running 19x8.5 35et with and 19x9.5 et25. 235/35 and 265/30. Rears are a bit aggressive and needed a little roll. Especially with my drop. The chart posted above is a big help and accurate
      11-27-2018, 07:05 PM   #3
squaredphoto
Poland
369
Drives: E91
2018 BMW 340i  [0.00]
Check out this calculator to compare sizes:
https://rimsntires.com/specspro.jsp
8.5 front and 9.5 rear will fit. I have 9.5 +35 square with 10mm spacers all the way around. The front pokes out a little bit but I had to use a 10mm to clear my coilovers.
      03-30-2019, 11:36 AM   #4
SparQ
Drives: E91 325Xi
Spring season is here, and I have decided to go with JR18 rims and just wondering if such build would fit stock E91xi suspension? Front: R18 235/40 9.5J, ET35 (not sure about ET) and rear: R18 265/35 10.5J ET35 (not sure about ET). If someone who has better understanding could suggest that would be great. Thanks
