TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Clutch Options?
      11-23-2018, 01:59 PM   #1
sdogatvman
Drives: Goal - 335 ST 6766
Clutch Options?
I am trying to find the cheapest clutch kit that I could run 700whp through. Options I have found are the spec stage 3+, 4, and 5. Running on a budget I would rather not have to pay over 700 dollars but I know that is a tough task. Any ideas would be greatly appreciated. Thanks
      11-23-2018, 02:02 PM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
Either Stage 3+ or go with a Twin Disc. At those power levels you need to pay to play. A clutch that can't handle the power won't do you any good.
      11-24-2018, 12:15 PM   #3
sdogatvman
Thanks Jeff. If I got a Twin Dist Clutch would there be any rattling noises?
      11-24-2018, 03:42 PM   #4
Ozzie335i
659
Drives: 2011 335i
No way around clutch "chatter," as above 500 whp the car is racecar. Raising the idle to > 900 RPMs may minimize chatter, but likely will not eliminate it entirely
      11-24-2018, 05:40 PM   #5
sdogatvman
Ok Thanks for the input. So is the spec stage 3+ the cheapest option for me?
      11-26-2018, 02:01 PM   #6
3441
As the other poster said, only way to avoid SMFW rattle is to up your idle. It will reduce a substantial amount of the noise.
3+ would be the least expensive/most practical drivability. It's good for 671 Torque.
      11-27-2018, 07:15 AM   #7
tisdrew
98
Drives: 2009 335i
Someone posted a link to buy the stage 4 which holds more and is significant cheaper BUT...the engagement is trash as it's a true 6-puck and their ads definitely says not ok for street/daily driving.
A number of single turbo owners run the stg2+ b/c the low-rpm torque doesn't exist with their tune so they can get away with less. As I have upgraded twins and love my torque by 3k, I've been looking over this same question and am saving up for a spec/motiv twin disc over the spec3+. Also, you'll want/need a steel smfw from mfactory.
"Wheels and exhaust aren't a build"
      11-27-2018, 10:51 AM   #8
3441
OP made some thread about Stage 4.
Stage 4, nobody will want that thing.
I prefer to recommend the Spec Flywheel only because it will then be offered with a sprung clutch option..
