11-22-2018, 02:36 PM | #1 |
Rep 48
Upgraded F30 Halogens to LED
Thought I'd share the end product of what it looks like in comparison to before. The whole headlight has been changed to LEDS, only thing required now is to code out the LED Checks. BIG DIFFERENCE
11-22-2018, 06:50 PM | #2 |
538
Rep 518
Drives: G82 M4, F15 X5, F30 328d, E30
Where did you get them? Link?
2022///M4 Competition BSM / Fiona Red.
2023 X7 xDrive40i, BSM / Individual Ivory white/Atlas Gray over Piano Black MSport Pro and Prof. |
11-22-2018, 11:44 PM | #4 |
19
Rep 153
I had mine for 3 weeks and so far got no flashing from other motorists. That is likely because I adjusted my vertical height cutoff down a lot to match my other vehicle's vertical height.
11-23-2018, 12:03 AM | #5 |
993
Rep 1,934
You put led bulbs in the projector from the pre-lci housing?
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
11-23-2018, 05:42 AM | #6 |
¯\_(ツ)_/¯
947
Rep 1,762
Same thing as throwing in an HID kit into halogen headlights. You are blinding everyone.
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
11-23-2018, 05:46 AM | #7 |
Luxury at the redline :)
9105
Rep 7,563
Dated article but it was the truth then as it is now:
https://www.autotrader.com/car-news/...dlights-258582 https://www.google.com/amp/s/amp.red...tting_any_led/ |
11-23-2018, 07:56 AM | #8 | |
19
Rep 153
Rathian155.00 |
11-23-2018, 08:06 AM | #9 |
8274
Rep 16,138
In this case the truth isn't the truth. What is factual is that an LED or HID bulb that's designed to duplicate the beam pattern of a halogen bulb via correct placement of the lighting elements in the bulb works perfectly fine in a lamp designed for halogen bulbs. This is easy to achieve with LED bulbs. It's not so easy with HID bulbs, though not impossible. My experience is that I had more problems with oncoming cars when I had halogens, as I had to aim them too high to see where I was going.
11-23-2018, 08:06 AM | #10 |
19
Rep 153
If you are talking to me, yes, mine is pre LCI. Had to do manual vertical height adjustment in the engine bay. It took some time as I had to do many turns with my key that is too short. Thus can only do short turn before I had to reposition again to turn.
I was determined to not blinding incoming vehicles, thus was adjusting until the height matches my other car with normal headlights. Indeed, if I did not do the adjustment, I would have blinded others. Last edited by Pdxway; 11-23-2018 at 08:38 AM.. |
11-23-2018, 09:35 AM | #12 |
19
Rep 153
My low beams is this:
https://www.amazon.com/gp/aw/d/B07H2...op_mb_pd_title I also got this for coding with bimmercode: https://www.amazon.com/gp/aw/d/B06XG...op_mb_pd_title I did the coding so that it won't blink during day time driving with DRL on. |
11-23-2018, 10:57 AM | #13 |
9105
Rep 7,563
You guys seriously believe that excessively bright aftermarket LED is not exhibiting more glare than a halogen bulb?
I mean, look careful, even the photo in this thread is blinding I don't expect you care or accept the truth but it's facts.. |
11-23-2018, 11:00 AM | #14 |
993
Rep 1,934
I still can't tell if it's an actual projector housing or just a bucket reflector. If it's just a projector the bulb will be fine
11-23-2018, 11:01 AM | #15 | |
Rep 48
Haven't been getting flashed, they're not as blinding as they look |
11-23-2018, 11:17 AM | #16 |
19
Rep 153
Sure. You have seen all LED in all cars and all are blinding.
11-23-2018, 11:34 AM | #17 | |
9105
Rep 7,563
11-23-2018, 11:55 AM | #18 |
1599
Rep 3,748
There are good LEDs bulb replacement out there...look for YouTube review.... check out blubfacts YouTube review.
Some or maybe lots of us here bought BMW's with halogen and regret it but don't want to buy an expensive conversion or even PnP HID headlight and just want a LED bulb. |
11-23-2018, 12:42 PM | #19 | ||
8274
Rep 16,138
11-23-2018, 12:45 PM | #20 |
19
Rep 153
Yeah, I have seen some myself. Just because you met some idiots, does it translate to no one should use led? If this is your way of thinking for everything in life, I feel sorry for your friends and family members.
SuhaibD989.50 |
11-23-2018, 04:58 PM | #22 |
Rep 48
