BMS Pedal Tuner; anyone? what say you¿
11-21-2018, 03:47 PM | #1 |
49
Rep 379
http://www.burgertuning.com/BMS_PEDAL_TUNER
just noticed this product whilst searching for black Friday deals. anyone used on a 335i or IS (preferably)? is it a gimmick or does it work¿ thanks!
11-21-2018, 04:13 PM | #2 |
996
Rep 2,287
Why?
Too many other options available. If your are curious, get the install instructions and look at the physical connections. You can learn the fact from fiction by looking at what signals it intercepts. |
11-21-2018, 04:39 PM | #3 | |
49
Rep 379
my biggest complaint of my 335is dct presently is that there is massive off the line lag. i still haven't read a fix for this, just a million and one recommendations that only seem to each make marginal if any differences. seems it is just a known issue of the 7sp DCT. are you saying that there are other products that can possibly fix off the line lag, or maybe this product won't even address that issue, not entirely sure honestly...?
11-21-2018, 10:30 PM | #4 | ||
421
Rep 1,643
2007 E92 335i MT
11-22-2018, 11:07 AM | #5 |
49
Rep 379
Who is bq, and how do i get a hold of this glorious sounding entity? Is that their handle on here? Thanks,
11-22-2018, 03:35 PM | #6 | |
421
Rep 1,643
Edit:: Oh look it got blocked! Beeequuuutuning hopefully you can figure out what I'm getting at with the address.
2007 E92 335i MT
11-22-2018, 05:48 PM | #7 |
Joint Chiefs of Staff
4918
Rep 115,980
The pedal tuner is a lot of fun, gives you on the fly ability to change the gas pedal gain, like the newer F chassis vehicles have with comfort/sport/sport+ settings. For the low cost I can think of worse ways to spend the money. It's not for everyone though and won't make your car faster at full throttle.
Mike |
11-22-2018, 08:28 PM | #8 | |
49
Rep 379
The biggest thing i miss about my old made in germany z4 os the immediate throttle response. No bull i would mash the gas at a green light and spin the tires into a very aggressive off the line sprint. My current 335is is nowhere close from the line. I mean from a roll it is more powerful, but from a dead stop it sits there thinking about moving for what feels like a second. If this is just something to increase throttle once I'm already moving i don't feel it is necessary for me presently as my rolling power is pretty sufficient ATM. I just want more off the line responsiveness without having to use launch control to achieve it.
11-23-2018, 07:03 AM | #9 | |
4918
Rep 115,980
Mike |
11-23-2018, 09:49 AM | #10 | |
996
Rep 2,287
If you mean Z4 3.0 is, you have made the exact same jump that I made, E85 to the E89 3.5IS. I wrote my owe tunes for both the engine and gearbox on the E85 and yes without launch control the older car seems much quicker for the first 30 ft. You need to remember they are both 3 liter engines but the E89 as 500 lbs more mass. That's hard to overcome especially without a manual clutch or torque converter to assist the the RPM build and torque multiplication. The TC can multiple torque by 2.5 : 1. Until the turbo's spool up the N54 is inferior to the N52. After spooling, it's a different ball game. I've called my car Dr. Jekyll and Mr. Hyde. Maintenance, plugs, coils and walnut blasting will keep the delay to a minimum. I good engine tune will tweak the waste gate settings and you need to be careful using any add on hardware that is designed to develop peak power at the expense of quick spooling. There is a chance that someone has cracked the TCU within the DCT and has modified the clutch pressure/RPM ramps to allow more clutch slip under higher torque demand/low RPM. I'm guessing this will certainly limit the life of the clutches. Their might have separate maps for Comfort, Sport and Sport+. Frankly I find Sport+ pretty aggressive. Just in case you have not verified this, I would log your "take off" to be sure the traction or stability control is not actually killing your take off. I've seen tires doing this with the E90 and E85 without illuminating the Traction control light. |
11-23-2018, 12:38 PM | #11 | |
49
Rep 379
it just seems like it doesn't want to let the clutch out very fast. i'm sure there are a lot of reasons for this, and i'm not sure it would be wise to have it dump the clutch on every take off either, but i sure miss that off the line reaction speed i had with my last z4. even my last two sedans in japan had really good off the line reaction speed; an 18 crown athlete (v6), and then an 18 3uzfe crown majesta (v8), and both of these cars had huge heavy ass vip wheels on em .
11-25-2018, 03:53 PM | #13 |
996
Rep 2,287
11-26-2018, 12:37 PM | #14 |
49
Rep 379
I put on zb8606072 which i believe is the latest 135is flash. if not the M, does the M have a 3500 launch control rpm setting? what are the pro's to the M over the latest 135 tcu flash zb8606072? thanks,
11-26-2018, 07:08 PM | #15 |
996
Rep 2,287
I was referring to this project
https://www.e90post.com/forums/showthread.php?t=1467719 https://www.youtube.com/watch?time_c...&v=qDN5ZgKqVUw |
11-27-2018, 10:00 PM | #16 | ||
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
