11-20-2018, 10:12 PM | #1 |
Rep 14
Code 102001 MAF issue?
A few weeks ago I installed a vrsf catless downpipe, charge pipe, and a intercooler.
Car was running pretty well until yesterday, it started throwing code 102001 "Air mass, plausibility -- Tuner code, ignore" and the feel of the car was drastically different. I've cleaned the MAF twice and checked the connections on the intake, they seem fine. Do I need a new MAF? Is there a way to know if mine is screwed up? or could I have leaks somewhere else that's making the car throw code? |
11-21-2018, 10:39 AM | #2 | |
272
Rep 823
11-21-2018, 11:33 AM | #3 |
Rep 14
11-21-2018, 11:48 AM | #4 |
1165
Rep 1,931
sell what you bought and buy the dinan if you need an intake.
I know dudes with 550whp + 2's with stock intake and a drop in filter. So go back to stock if you have to.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
11-21-2018, 12:49 PM | #5 |
272
Rep 823
11-22-2018, 01:34 AM | #6 |
340
Rep 716
Drives: F90 M5
Yea, back when i used to run the BMS intake, I got a code (code can be cleared via custom tune, Enzo Racing did mine and it cleared the code) But the code was from the intake, now i am on the stock airbox with a BMC filter no problems at all.
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
12-09-2018, 12:10 AM | #8 |
Rep 2
I have a 2015 M235xi with catless downpipe, bms intake, and a jb4.
I just received that same code im trying to figure it out, nothing i have done worked. Im probably going to take it to the shop, but i prefer to do myself to save money. |
12-09-2018, 02:33 PM | #9 |
Rep 44
Put your stock airbox back on, clear the code, see if it comes back. If it does, could be a dirty or faulted MAF sensor.
12-10-2018, 11:18 AM | #10 |
97
Rep 373
102001 air mass to high, I literally just had the same code show up through bootmod3 yesterday. The car was doing some very weird things like jerking during light acceleration and then cutting out at a stop street going into neutral. It turned out to be an incorrect fitment of my charge pipe it was not seated onto the cooler correctly. after we sorted that out the car is perfect and the code has not come back.
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
07-18-2020, 07:54 AM | #11 | |
Rep 1
I’ve just seen this post because I’ve got the same issue as you, What exactly did you do to fix the problem, the garage that fitted it said it’s fine but will double check everything, I’m just wondering what the exact problem was and how to fix it so I can pass it on to the garage, Thanks |
08-02-2020, 06:11 PM | #12 | |
16
Rep 89
08-12-2020, 07:29 PM | #13 |
Rep 15
What did u do for the solution, I’m currently having the same issue that someone else had above where the car stalled at a stop and I had a code 102001 I put the stock air box back on thinking it was my Cts intake but it wasn’t. Should I do a smoke test to check for boost leaks I have a vrsf cp and IC.
08-13-2020, 12:13 AM | #14 |
5565
Rep 5,378
You guys have intake leaks somewhere. My guess is at the charge pipe rubber section that joins the two pipes or the charge pipe connection at the intercooler.
Do all of you have VRSF charge pipes? |
08-13-2020, 06:47 PM | #15 |
Rep 15
Yes I have a vrsf charge pipe and thank you I will try to check it out tomorrow.
08-14-2020, 12:53 PM | #16 |
16
Rep 89
Unfortunately, I don't have a charge pipe yet, I just got the car on bootmod3, I believe you are right and will take a look at it this weekend.
08-14-2020, 01:02 PM | #17 |
16
Rep 89
08-14-2020, 07:34 PM | #18 |
Rep 15
08-17-2020, 07:16 PM | #19 | |
16
Rep 89
08-20-2020, 09:23 AM | #20 |
Rep 15
Yeah I found mine too with a smoke test. Turns out one of the bungs for meth on my charge pipe blew off somehow so I had some screws with thread locker on it now and it runs fine.
09-10-2020, 08:15 AM | #21 |
97
Rep 373
100% charge pipe related
