Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Alloys sticking to hubs
      03-20-2006, 09:29 PM   #1
dom1
dom1's Avatar
Drives: 2006 330xi
Question Alloys sticking to hubs
A friend of mine has an E46 and had to call roadside assistance due to a flat because he could not get his tire off the hub. I guess his wheels got stuck to the hub and no matter what he did, he couldn't get it off. Since I plan to change between winter and summer tires, I did some research and found a product from Kleen Wheels advertised in "Bavarian autosport" magazine. This product is a non-metalic disc which mounts between the wheels and the BMW's hubs to prevent the wheels from sticking to the hubs due to corrosion. (It is not the product intended to prevent wheel dust from getting into the wheels.) Here is a link to the product...
http://www.kleenwheelsincolor.com/kw...0mate_info.htm
Has anyone had experience with this product to recommend it or not?
Thanks in advance.
2006 330xi MB, Terra, Burl Walnut, Auto, PP, Nav, Heated Seats, SP w/18in
2002 Acura MDX - wife's ride
2000 Ford Expedition Eddie Bauer 4x4 - wife's SUV retired after 120K miles and lots of problems
1994 Pontiac Sunbird 4 cyl. - retired after 170K miles
      03-20-2006, 09:47 PM   #2
ward
155
Drives: F
get some white (low temp) grease
that's all you need
I'm serious here, (for once)
      03-20-2006, 10:10 PM   #3
hotsand5
hotsand5
hotsand5's Avatar
49
Drives: 2006 BMW 330i 6spd
2006 330i  [0.00]
that should be all that you need. Can you use that pink petroleum jelly as well?
-2006 BMW 330i-Sapphire Black- Tera Leather-Aluminum trim- 6spd manual- Sport- Premium- Cold- Navigation- Euro. delivery
-2005 Yamaha Warrior 1700 102cu"
      03-20-2006, 10:16 PM   #4
Artz 330
196
Drives: Z4M, 335i, 135i
2006 330i  [0.00]
yea, any type of jelly type grease will due fine. I had this same problem on my 330Ci and my MINI cooper S, so on the first rotation i smacked on some jelly and havent had issues. Before i needed Huge rubber mallet to get my wheels off LOL. My e90 is still only 4 months old so i havent taken off the wheels yet.
      03-20-2006, 10:47 PM   #5
Ghunger
Ghunger's Avatar
52
Drives: 330i
The grease would definitely work but I bet there's something you could DIY to act like that spacer they're selling. It would be a lot cleaner than the grease and probably wouldn't cost much. You might also be able to paint the mating surface of the wheel to keep it from getting stuck. You'd have to be careful preparing the surface (cleaning and roughing up the wheel) or else the primer and paint won't stick well. Just a couple ideas.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep
European Delivery Blog
Picture Gallery
      03-20-2006, 10:52 PM   #6
Chesmu
Chesmu's Avatar
89
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
you might not even need to paint. Just roughing up the surface wouldprevent the hub and wheel from sticking. Two ultra-smooth surfaces will always bond together. A little bit of incongruity will keep the two surfaces from sticking.
"Teach the ignorant. Ignore the stupid."
      03-21-2006, 04:41 AM   #7
D.D.
Drives: 330 xi
I have used these on my MINI Cooper S as I had the same problem...the wheel welded to the hub!!! They work absolutly easy and I've never had a problem with wheel removal again. I ordered a set for my 330 xi as I've dumped the run flat wheels. They work very well and are worth the money. They do take some patience when lining up the bolt holes and placing the wheel on....but they do work!!! :rocks:
      03-21-2006, 04:57 AM   #8
Volume
Drives: Sparkling Graphite 330I
Anti-seize(the silver looking stuff) works great! Just rub a little bit on the parts between the wheel and rotor that come in contact. This will stop corrosion from causing the wheels to seize
      03-21-2006, 09:20 AM   #9
JIMD1709
JIMD1709's Avatar
31
Drives: 2007 328 Coupe Alpine White
Anti-seize is correct. This is what the factory, and BMW centers use. Grease won't repel grime and dirt as well.
      03-21-2006, 10:20 AM   #10
dom1
dom1's Avatar
Drives: 2006 330xi
Do regular auto stores like AutoZone and PepBoys carry it?
      03-21-2006, 11:24 AM   #11
Bimmerista
Bimmerista's Avatar
82
Drives: superstock
Yeah, where do you get anti-seize ?
      03-21-2006, 11:24 AM   #12
dkizerian
Digital Ruler
Drives: 325i AW/Terra
Yes!
anyplace that sells bolts should sell a brand of it. In an autoparts place you'll probably find in in the same area as threadlock.
      03-23-2006, 08:41 AM   #13
JIMD1709
JIMD1709's Avatar
31
Or get it here
http://www.bavauto.com/shop.asp
Search "anti seize"
