Can’t get serpentine belt back on...
11-19-2018, 01:43 PM | #1 |
1044
Rep 1,667
Okay so I know I’m gonna feel like a real moron after this gets answered but try as I might I can’t get the belt back on my n54...see the attached pic. It feels like the belt is too short although i compared it to the belt I took off and they are the same length. I can get the tensioner fully bottomed out against the stop and the belt is still about 1.5” from going around the top tensioner pulley...any insight???
11-19-2018, 01:56 PM | #2 |
233
Rep 564
I believe this is the routing you want to use
Other than that, if I'm remembering correctly I found it easiest to run the belt fully and then slip it on the tensioner pulley last while putting weight on the tensioner to give me some slack. Maybe get a second hand to hold the tensioner while you route the belt? A long breaker bar makes it easier if you're doing it alone, the shorter your ratchet the more difficult it is to hold the tension off. Edit: Also make sure you didn't get the belt hung up on anything down towards the bottom. You should be able to get your hands down there and feel around. It took a little bit of maneuvering to get my belt to sit perfectly Edit #2: Looking at it again, I think I used the pulley under the tensioner pulley as the last one to wrap around. Something about that one just seems easier to put on last. Last edited by nissubaru; 11-19-2018 at 02:05 PM.. |
11-19-2018, 02:37 PM | #3 |
647
Rep 779
+1, is your belt even around all of them? Obviously, make sure you got the right belt length.
Can't see if the tensioner is compressed (doesn't look like it), but fully compress it and use a pin or similar through the holes to hold it until the belt is installed. That spring is stout, make sure whatever you use is solid and has no chance of popping out. New belt is a somewhat snug fit even with the tensioner fully compressed. Get it routed and then pull the all slack out at the last pulley, make sure the ribs are in the grooves and that it's seated properly on all pulleys or you likely won't have enough slack to get it over the last one (tensioner or tensioner idler probably is best). |
11-19-2018, 03:35 PM | #4 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Username does not check out apparently..
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
b92539.50 OTO335i144.50 Needbmwpartzz851.00 N54Society448.50 rohitsja232.50 Bimmer_Engineer1043.50 TheMidnightNarwhal2657.00 feuer4275.50 cali__n548.00 |
11-19-2018, 04:52 PM | #5 |
1044
Rep 1,667
Antetokounmpo1551.50 |
11-20-2018, 05:31 AM | #6 |
145
Rep 506
I believe there's a couple different ways the belt can be routed on our engines, i ran into the same issue the first time i replaced mine and i wasn't routing it correctly. I had found 2 different ways in Google for the N54, i guess it depends on what year the motor was made or something.
2010 335I Xdrive
You're not really driving if you don't have 3 pedals. |
11-20-2018, 09:16 AM | #8 | |
233
Rep 564
As far as I know there are two ways, this thread below is where I discovered this information https://www.n54tech.com/forums/showthread.php?t=11957 I believe the problem with the original way of routing the belt was that it could potentially come in contact with the subframe so it was re-routed for better clearance. If this affects the length of the belt, I'm not sure. All I can say is I bought a Continental belt recently from FCPEuro and had no issues with fitment. |
11-20-2018, 09:54 AM | #9 |
4276
Rep 9,206
Is installer error. Old and new belts are same length. Change of username is in order.....
11-20-2018, 01:34 PM | #10 |
1044
Rep 1,667
Just to clarify I’m not trolling you...the routing diagram on realoem and of pictures I’ve seen of n54 engines shows a different routing than what I ended up using...and I’m an engineer...I don’t typically do stuff half assed until I ensure the full assed way isn’t working for a valid reason...no point in reinventing the wheel or breaking something needlessly...
11-21-2018, 07:59 AM | #11 | |
Guest
Rep n/a
Drives:
Please provide examples. How does rerouting the belt provide better clearance between the PS pulley and the subframe..?? |
feuer4275.50 |
11-21-2018, 08:15 AM | #12 | |
2657
Rep 6,290
Here is the thread which was originally discussed and has the pics. https://www.n54tech.com/forums/showthread.php?t=11957 |
11-21-2018, 08:25 AM | #13 | |
1044
Rep 1,667
11-21-2018, 12:35 PM | #14 | |
4276
Rep 9,206
11-21-2018, 12:47 PM | #15 | |
2657
Rep 6,290
06-14-2019, 09:46 AM | #16 | |
Rep 1
06-14-2019, 01:28 PM | #17 |
145
Rep 506
Read through the whole thread. You're probably not routing it correctly, There's 2 different ways.
2010 335I Xdrive
06-18-2019, 10:48 AM | #18 | |
233
Rep 564
I would probably suggest starting at the bottom and continuing to pull the belt tight as you work your way up. Idk...it took me like 2 minutes last time using the routing that I posted further up in this thread. |
03-06-2021, 03:21 PM | #19 |
Rep 1
BMW 335I E90 2008 Shreaded serpentine belt
Hi Guys,
I have a 2008 335I with 48K miles. Recently the original serpentine belt die catostraphically. It was totally shreaded. I installed a new serpentine belt... It also shreaded in a matter of days. I figured it was an ancillary component that could be locking up. Over stressing the belt and killing it. I thoroughly inspected all ancillary components which seemed to rotate smoothly. HOWEVER, during the inspection I found that pieces of the old belt were entangled in the alternator and parts of the belt were behind the power steering pump. My thought was that the old pieces of shreaded belt were getting into the new belt/pulley and kicking off the belt. I thoroughly inspected the entire front of the engine, pulled off the harmonic balancer, inspected for belt pieces, inspected the main seal and buttoned everything back up... Bought a new belt and installed it. While the engine bay was still open we started the car and inspected the operation of the belt. Incredibly within a matter of minutes the belt was kicked off the pulleys and was shreaded.... FURTHER INSPECTION found that the power steering pump bolts backed out leaving the air pump non-secured. The mis-alignment of the air pump kicked the belt off the pulleys the subsequent rotation of engine ancillary driven parts killed the. Lesson learned... IF your car shreads belts. Look at proper attachment and alignment of all components. I tightened all ancillary drive components, installed another new belt and it runs great. |
03-06-2021, 05:06 PM | #20 | |
206
Rep 498
