Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > TPMS sensors: How to figure out correct model?
      11-17-2018, 09:50 PM   #1
monkeyboy
13
Drives: 2007 E90 328xi
I've got a 2011 328xi. A little while ago I swapped in some old tires/wheels from my earlier 2007 328xi. The TPMS did not work from these wheels. Now I want to get the right TPMS sensors for these wheels as I put on some new snows.
How do I figure out the right model? I gather 2011 was a transition year and it is important to figure out the production date? (how do I do that?). I don't want to have to tear apart the existing "good" wheels or dig around in the car itself if I don't have to...
Looking at part 36106856227... seem correct? Thanks.
      11-18-2018, 12:09 PM   #2
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
go here: https://www.realoem.com/bmw/enUS/select
enter last 7 of vin and it'll pull up the correct p/n for everything since it can tell your production date.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      11-18-2018, 01:13 PM   #3
monkeyboy
13
That's quite helpful, thanks.
Unfortunately if I'm reading the search results correctly, it seems to be indicating at least two different TPMS sensors being used in those models which are "non-exchangeable retrospectively", namely:
36106856227 3' E90 LCI (07/2007 — 12/2011) (the one I originally found)
36106790054 (09/01/2009 — 06/13/2013), non-exchangeable retrospectively
also
36236781847 (07/01/2007 — 06/13/2013), Exchangeable retrospectively
Does this mean I can't know unless I dig through the car or "good wheels"?
HUF reports that the 0054 part will work, but can I trust them?
      11-18-2018, 08:32 PM   #4
Antetokounmpo
1552
also
Hmmm. Looks like the first 2 parts numbers (ending in 27 and 54) are the same part. Look here: https://www.fcpeuro.com/products/bmw...856227#fitment
The third one (ends in 47) is for cars up to 08/2009, look here: https://www.fcpeuro.com/products/bmw...798726#fitment
Weird how both come back with real oem, usually they are spot on. Something like the first fcp link should work according to their site as they are good for E9x 328i after 09/2009 production
      11-18-2018, 09:47 PM   #5
monkeyboy
13
yeah, I noticed that HUF tends to lump the '27 and '54 together... what threw me was realoem stating that '54 is "non-exchangeable", which means "can be incompatible", no?
      11-19-2018, 08:15 AM   #6
Antetokounmpo
1552
The non-exchangeable nomenclature is strange, it looks like to me that huf makes a sensor that covers both part numbers so it will work with either.
      12-03-2018, 08:22 PM   #7
monkeyboy
13
just to confirm that the HUF rde012 worked fine... $37/ea delivered.
Appreciate 2
Jklad421.00
      12-03-2018, 09:47 PM   #8
Antetokounmpo
1552
Glad to hear it worked out.
