Is it a good idea to buy N54 335I or should I go for the N55?
11-16-2018, 05:57 PM | #1 |
Rep 8
Hey, guys! New member here. I'm currently a MK VI GTi driver, and want something that delivers more driving pleasure than the GTi. I'm also planning on tuning the car, aiming to get around 400hp on wheels. Looks like the E90 3 series is the way out. I did some research on the N54 motor, it seems that the problems of this engine is never gonna be fully resolved? Due to this reliability issue, I'm hesitating on whether to get a N54 335 or the later N55 version. Can anyone give me some advice? Or is there anything drives like the E90 3 series?
11-16-2018, 10:10 PM | #2 |
Save the manuals!
6016
Rep 6,746
If you want the absolute best everyday reliability while still being some fun, get a 328i. If you prioritize power and tuning, get the N54. If you want a slightly more reliable platform while still offering good power, get the N55.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
11-17-2018, 06:16 PM | #4 |
Save the manuals!
6016
Rep 6,746
lol, there is... My previous post didn't suggest the N55 is not desirable. Its more reliable than the N54 but a little less tuning potential. If I didn't have a 328, I would absolutely look for a N55 335i
11-17-2018, 06:26 PM | #5 |
31
Rep 110
Drifter2090909.50 |
11-17-2018, 07:04 PM | #6 |
551
Rep 2,293
if you are on a budget and you are already stretching it by buying a used BMW , I would advice to get a N52
However if your budget allows you for an extra 2000-3000 maintenance out of nowhere go with n54 or n55 ( probably the latest) Also if you are just buying a bmw to go from point A to B and some street fun , nothing wrong with any of the 3. However if you want drag or track use, probably N54. However once you start modding a used car, reliability becomes an issue , so I hope you can wrench and you have a spare car |
11-18-2018, 07:07 PM | #7 |
Rep 8
11-18-2018, 07:08 PM | #8 | |
Rep 8
11-18-2018, 08:27 PM | #9 |
31
Rep 110
11-18-2018, 09:14 PM | #10 | |
551
Rep 2,293
N55 should be safer, if you just want a little more power, however keep in mind those cars are already getting old so they still need regular maintenance. Just to give you an idea for the non turbo n52 , regular maintenance at around 60 000- 85 000 miles is water pump ( 500-800 $) , coils and plugs ( 600 $ ), brakes/ rotors ( 600 $) , fluids ( 600$) , suspension ( 300-500) those are very very rough numbers, but it gives you an idea of what a non turbo maintenance is already like , now on a turbo car is those items I already mentioned plus the turbo components ( injectors, walnut blasting, turbos , hpfp ) . I mean , you ll be very unlucky to get all those at the sametime , but you ll probably get a few ... Thats why I said if you can wrench , you could save a lot of money ... I would personally keep 2-3k in the bank just for maintenance . So if your budget is 15k , get a car for 12k and keep 3 k for unexpected maintenance. The trick with these cars is being ahead in the maintenance to avoid big bills. So if you buy a used car, change all the fluids , replace the plugs and coils , etc ,etc etc |
11-18-2018, 10:58 PM | #11 | |
Rep 8
11-19-2018, 11:03 AM | #12 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
Hey rick can I get a contact for your suspension guy? I can't even buy springs for less than 300. Refreshing an E90 suspension can get up there especially if you start to look closely at all the bushings and control arms that naturally start to wear out.
6ixSpd6015.50 |
11-19-2018, 11:18 AM | #13 |
Rep 166
Also I would listen to the n55 exhaust vs the n54 Any way I can only speak to the n54 platform through experience. The best mod you will ever do is tune. Not only from the performance aspect but the code reading. With out the JB4 / MHD setup I really would have been chasing too many issues in an attempt to fix things. Just finished the an o2 sensor this weekend which started at a misfires etc etc etc. Being able to delete codes and continuously read codes really helps track things.
There is tons of support for both platforms and every bolt on is about $450 cad or thereabouts on the used market. My biggest grip is not adding power but planting power. You will get fast quickly. I am hoping that m3 suspension bits will solve that. If it does not it I will move on. No point having 380 or what ever and afraid to punch it... That being said my car is a moderately fast marshmallow which hopefully will be fixed soon. So I would say get something with at least the sports suspension to start and go from there suspension wise. Power wise would just be the patch to FBO. Happy hunting ! -B |
11-19-2018, 04:34 PM | #14 |
407
Rep 2,704
If you want to achieve 400 hp, both platforms N54/N55 are ok.
Personally I drove my N54 to 200K+ in KM milage and just had the regular issues. Water pump, oil gaskets spark plugs etc. clutch changed 3 times, walnut blasting. So just realize the car needs maintenance, the more you give back to the engine the better it treat you. I actually sold my 355i N54 to my mechanic and bought the M5, so yes he liked it that much cause my car ran great! budget 2K a year to cover worries - you'll be fine. |
11-19-2018, 07:06 PM | #15 | |
551
Rep 2,293
why would you need springs at 60-85 000 miles? At that mileage you ll probably be ok with most of the suspension components. 300-500 bucks can get you a nice wheel alignment , maybe a control arm . Which are probably what you would need if you were to buy a used car that Very rarely someone is going to buy/sell a car that is not driving straight , has a crooked wheel , or is making noises. most of the guys getting full suspension refresh below 85 000 miles are guys doing it because they just want to upgrade handling , not because they actually need it . Most people are not even going to bother selling their cars if it has a bad suspension component that requires intimidate attention, unless they want to waste their time or get low ball hard I got coilovers on my car at 68 000 miles, only thing they replaced was the front control arms just because they had some played , but even the mechanic told me you could still be ok for another year . I just told him to change it . And I drove the car year round , hitting big pot holes in the canadian winter. Heck I even blew a tire and crack rim badly last year. Suspension on these cars are rock solid for the most part My wheel alignment was 120 dollars , just because some bolts seize and the mechanic had to spend more time on it. Last edited by rick100; 11-19-2018 at 07:11 PM.. |
11-20-2018, 07:31 AM | #16 |
148
Rep 388
I bought my one owner e92 n54 335i with 70k miles on it over a year ago. In 8k of ownership...
So far I have replaced... hpfp ( 2nd one) Shocks ( they started to leak) now have CO's Had the valves blasted ( they were caked in sludge) TC sensor Now my clutch is done and the oil pan gasket is leaking. Plus a head light error. These cars are a PITA in your wallet for an out of warranty car. |
11-20-2018, 04:58 PM | #17 | |
Rep 8
11-20-2018, 11:03 PM | #18 |
curtisR
13
Rep 57
Hey
I have a 2011 335is (n54), I absolutely love the car. Ive owned it for about 3 years now and I have zero complaints. In my ownership Ive only had to change spark plugs and coil packs. I'm currently at 110k KM and making 427whp 479wtq. My previous 07 335xi 6MT was fbo and I sold it at 210k km with zero problems, I say if you're slightly mechanically inclined go with the n54.
Montego Blue 335i 6MT- FBO with RB turbo's and meth
Alpine white 335IS DCT- FBO with meth |
iScramble76.00 |
11-21-2018, 06:11 AM | #19 | |
76
Rep 128
11-21-2018, 02:55 PM | #20 | |
Rep 8
11-21-2018, 02:57 PM | #21 |
Rep 8
So how do you diagnose N54 or any other engine problems? Any tricks on keeping track of things?
11-21-2018, 05:10 PM | #22 | |
76
Rep 128
