TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Symptom of bad valve cover gasket (or cover)?
      11-12-2018, 04:39 PM   #1
Phil G
Dominator of Deep South curvy roads
Phil G's Avatar
51
Drives: '07 335i Coupe
I recently pulled off the engine cover and noticed oil sitting in the little metal dimple next to the wires for the #2 injector (picture attached). Is this the sign of a valve cover gasket (or valve cover) that needs to be replaced?
FYI - Car has 164k miles, and the valve cover gasket was last replaced around 130k miles by an indy mechanic. Thanks for the help!
-'07 335i coupe (build date 02/2007) - Space Grey/Black Dakota/Dark Burl - 6MT/ZPP/ZSP/Nav/CA/Heated Seats. Acquired in Munich 3/2007 via European Delivery. 16 years and almost 220k miles of pure joy!
-'06 911 Carrera S - Black/Black - Full Leather/Sport Chrono/Porsche Sport Exhaust/Nav - 80k miles. Acquired 1/2021. One needy old German car just wasn't enough!
      11-12-2018, 05:09 PM   #2
SnailBums
34
Drives: e60
with leaks you always want to look for the highest point of saturation. also if it was recently replaced it might be residual/ not cleaned.
if i was you i would take a few cans of brake clean, spray it down and re-check after a few days.
mike
      11-13-2018, 03:05 PM   #3
Phil G
Phil G's Avatar
51
mike
Great point, I didn't even think about the fact that the oil may have been left over from the last VCG change. I'll do just that - spray down the engine and better pinpoint the leak (if there is one). Thanks for your help, Mike!
      11-13-2018, 03:26 PM   #4
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
That is not what 'previously not cleaned oil' looks like especially after 34K miles.
You have a leak. Either gasket or cracked cover.
      11-13-2018, 03:32 PM   #5
SnailBums
34
Drives: e60
so instead of spending $5 bucks for brake clean and cleaning it off to recheck you would rather just throw parts at it. great logic! forget diagnosis/actually looking into something. just throw the common shit at it.
Mike
      11-13-2018, 03:43 PM   #6
Wolf 335
Wolf 335's Avatar
2341
Mike
No Mike. Obviously common sense is to clean it off first, simply to see the rate at which is leaking.
Are you seriously saying that oil that leaked 34,000 miles will look that fresh on a part that goes through numerous heat cycles?
I hope that I am wrong, for the sake of OP.
