Help Needed !! Immediately
11-09-2018, 03:23 PM | #1 |
62
Rep 126
2013 E92 335i N55
So i just Purchased some OEM bmw coolant and it seems as if there is Green coolant in my Expansion which leads me to believe it is also in my whole system . I'm really confused as to how i can flush it all out and add My Bmw coolant + Distilled water ! Anything helps guys |
11-09-2018, 03:58 PM | #2 |
Is it the shoes!?
3884
Rep 5,112
Remove the black Phillips head radiator drain plug, be sure not to break the hex cap it screws into - it's not meant to twist or come out.
Drain the coolant, pour in distilled water, and bleed the system by holding the gas pedal down. Literally, rinse and repeat until water comes out clear. Last edited by Welcome to NBA Jam; 11-09-2018 at 04:31 PM.. |
TemjinX2520.50 |
11-09-2018, 04:18 PM | #3 |
521
Rep 1,484
yeah flush it...my co worker's mechanic put the cheap autozone green coolant into his vw....it mixed with the oem coolant and turned it into jello and over heated his engine.
11-09-2018, 09:24 PM | #4 | |
62
Rep 126
11-09-2018, 09:27 PM | #5 | |
Is it the shoes!?
3884
Rep 5,112
https://www.pelicanparts.com/BMW/tec...ing_System.htm |
