Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > STFT Question - Logs Attached
      11-02-2018, 07:37 PM   #1
savannahz
21
Drives: 2016 M4 Vert
Hey,
I just changed out my lpfp as I was dipping below 50 in higher rpms. Everything looks good now except my stft are fairly eratic and above 5 apart. They were this way before and after an adaptation resets.
I've tried reading around but still don't understand if they are within reasonable spec. The idle looks good which means my injectors are alright? But, since they become farther apart at higher rpm it could be o2 sensor?
My afr looks good and the car runs well so maybe I shouldn't be concerned?
Thanks!
just idle: https://datazap.me/u/savannahz/idle-...&data=20-21-22
idle then higher rpm while in neutral: https://datazap.me/u/savannahz/idle-...&data=20-21-22
      11-02-2018, 09:07 PM   #2
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
I see nothing weird about your trims. if you want better advice, log an actual run from low rpm to redline.
Fuel control is closed loop. STFT is the amount of trim the DME is applying to hit the AFR dictated in the AFR tables. variance bank to bank is expected and is due to a lot of variables. Either way, the logs you attached are not telling.
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      11-02-2018, 10:05 PM   #3
savannahz
21
Here is a pull I did today in third gear from 3k to redline: https://datazap.me/u/savannahz/11-2-...&data=20-21-22
Looking back, maybe it's not as bad as I thought. It's only largely separated in brief moments.
      11-05-2018, 10:22 AM   #4
335e92tx
ahat
335e92tx's Avatar
1036
Drives: Was '07-335e92 - Now '13-335IS
Link didnt work - is this the one you wanted?
https://datazap.me/u/savannahz/idle-...ata=3-20-21-22
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos.
https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8
      11-05-2018, 01:02 PM   #5
savannahz
21
Sorry, I had made it private...here you go: https://datazap.me/u/savannahz/11-2-...&data=20-21-22
Thanks!
      11-05-2018, 01:06 PM   #6
9krpmrx8
Clean is the new cool, keep it that way.
9krpmrx8's Avatar
808
Drives: 11' Alpine White 335i Sedan
Everything looks fine to me.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive
      11-05-2018, 02:23 PM   #7
NA55
32
Drives: 335i
The STFT at idle does look a little odd.. i checked mine and it looks stable.. the STFT at WOT looks ok..
      11-05-2018, 02:28 PM   #8
9krpmrx8
9krpmrx8's Avatar
808
Smile
It only matters at warm idle and anything within 5% + or - from 0 is normal for STFT and LTFT.
2015 X5 35i Xdrive
      11-06-2018, 07:08 AM   #9
savannahz
21
Thanks for all the responses. I feel better about the readings.
      11-06-2018, 07:25 AM   #10
FCobra94
Guest
n/a
Drives:
How many miles on car? Still on stock injectors?
What do the trims/AFRs do when you let off the gas completely after making a pull?
      11-06-2018, 06:23 PM   #11
savannahz
21
The car has 81k miles. The injectors were swapped out while in the teens as the fuel pump and whatnot went out before I had it when it was a lease. They are the older index injectors (same index it originally had in 2007...9?).
Here is a pull I did where I just let off the gas at the top of the run and just kept it in gear. The afr goes and stays at 234.95
https://datazap.me/u/savannahz/third...&data=14-15-20
Thanks
      11-06-2018, 10:19 PM   #12
335e92tx
ahat
335e92tx's Avatar
1036
Thanks
Time to replace o2 sensors. Look how long it takes for lambda to go to 234 after throttle closure..
They are slow.
      11-07-2018, 05:12 AM   #13
FCobra94
Guest
n/a
Drives:
https://datazap.me/u/savannahz/third...;data=14-15-20
Thanks
They are slow.
That's what I was getting at, but my thinking is that this is pointing to leaky injectors...refreshing primary O2s is not a bad idea though.
      11-07-2018, 01:08 PM   #14
savannahz
21
Thanks for the great information
I have been getting for the past several months a 2C7F trimming "lambda control 2" code. It's a shadow code and I haven't been able to get anything out of my research short of ignore it as I have catless dp's.
Last time I checked my plugs to see if they were wet they looked good. I'll do another check.
I should probably replace the oxygen sensors due to age anyhow. We are talking about the two closest to the engine (is that upstream)?
Looks like the Bosch 17098 is a reasonable option? Can I use this for both banks, or do I need to use Bosch 17102 for cylinders 4-6?
Is it just the wire length that's the difference?
      11-07-2018, 01:44 PM   #15
FCobra94
Guest
n/a
Drives:
Yeah, just wire length...go with the cheaper option (17098).
      11-07-2018, 02:38 PM   #16
savannahz
21
Awesome, I just ordered a couple and will update the thread once I get these installed with a new log. I have noticed my gas mileage went down by a couple over the past half a year, or so.
Again, you guys are great and I really appreciate the help!
      12-11-2018, 04:06 PM   #17
savannahz
21
They are slow.
I replaced both primary O2 sensors and have a new log. I tried to do what you did in the screenshot, but couldn't figure it out...do they still look slow? Are the sftf numbers too far negative at the beginning of the run?
thanks!
https://datazap.me/u/savannahz/log-1...ata=3-22-23-24
excel log screenshots before and after 02 replacement:
View post on imgur.com
      12-12-2018, 08:52 AM   #18
FCobra94
Guest
n/a
Drives:
Looks good to me.
You can always reset adaptations and try again though.
Appreciate 2
335e92tx1036.00
      12-13-2018, 03:35 PM   #19
335e92tx
ahat
335e92tx's Avatar
1036
yep, looks like they are to full lambda in .4 sec.. I doubt you can get much quicker. Looks like it took .7 secs before.
Appreciate 2
      12-13-2018, 06:58 PM   #20
savannahz
21
wow, that's awesome. Thanks for taking the time. Makes me feel a lot better.
Thanks to everyone for their help...means a lot.
335e92tx1036.00
