10-31-2018, 11:10 PM | #3 | |
17689
Rep 8,486
I'm not aware of an issue with the M4'S drive shaft but do know it's no longer made in CFRP.
10-31-2018, 11:33 PM | #4 | |
316
Rep 719
///M TOWN17689.00 |
11-01-2018, 12:21 AM | #5 | ||
17689
Rep 8,486
I guess that's why they stopped making the CF version.
11-01-2018, 03:52 AM | #6 |
483
Rep 758
Drives: M2
It does not seem to be a CF issue but how the shaft is matted (bonded?) to the flange. I wonder if the replacement drive shaft will be CF. Assuming not, what would the weight difference be between a CF and steel (?) drive shaft? Would there be an impact on performance?
'17 M2 DCT Long Beach Blue
11-01-2018, 09:11 AM | #8 |
270
Rep 486
its the non cf shaft thats being recalled. cf was in 2015. 16 & 17 m4's didnt have cf shaft
AndrewC198910932.50 |
11-01-2018, 09:22 AM | #9 |
Chief Warrant Officer
1025
Rep 1,638
Coincidentally, just the other day I was watching a video of a high-powered twin-turbo mustang with a CF driveshaft. On the second launch the CF driveshaft literally disintegrates.
It doesn't just break - it comes apart into a pile of dust and fiber stretched out behind the vehicle for 15 feet. I guess CF driveshafts are not really suited for high-torque applications.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
11-01-2018, 09:30 AM | #10 |
Luxury at the redline :)
9105
Rep 7,563
Carbon fiber is an extremely strong and light combo, its what they trust to use for aircraft components..
I am pretty sure this batch of defective driveshafts are just related to the adjoining flanges and not the quality of the carbon fiber material.. |
11-01-2018, 09:45 AM | #11 | |
1025
Rep 1,638
In almost all aviation applications, torque is a limiting factor on structural and drive components (i.e. you must restrict torque below x-value - exceedance may cause failure). This makes sense to me. CF, being a non-homogenous mass, would not be ideal for applications applying extreme stresses on multiple axes simultaneously.
11-01-2018, 09:47 AM | #13 |
1025
Rep 1,638
I had a CF driveshaft on my old Mazda RX-8, but even modified, that was a high-revving HP car, not a torque-producer.
11-01-2018, 09:47 AM | #14 | |
270
Rep 486
11-01-2018, 09:55 AM | #15 | |
1025
Rep 1,638
That increase in size won't fit. So, they have to go back to a material that can handle the stresses and still fit in the space available (IIRC, the reason for the space limitation has something to do with the new particulate filters).
Poochie9104.50 |
11-01-2018, 10:10 AM | #16 | |
270
Rep 486
Where did you get that from? I think its more probable they moved away from CF to cut cost vs an actual integrity concern. BMW claimed its do to emmisions. Race cars have preferred carbon fiber drive shafts over steel for years. |
11-01-2018, 10:15 AM | #17 | |
1025
Rep 1,638
It's possible I'm wrong, but this isn't the only place I heard that. And yes, it's due to emissions because the new emissions hardware (particulate filters) give less room for a driveshaft, so a thinner DS is needed than can be built from CF (CF may have better strength-to-weight ratio than steel, but given equal dimensions, steel is stronger). I'm not saying CF isn't a good option if you can make it big enough, but in this case, it seems space constraints won't allow them to use a CF DS because it would have to be too large for the space in which they have to work.
11-01-2018, 11:25 AM | #18 | |
5865
Rep 6,637
New owners claimed to get cf drive shaft up until sometime this year! let alone 16-17. |
11-02-2018, 06:44 AM | #20 |
2543
Rep 3,968
CF shaft in the M3/M4 till late 18 in the NA. (Nobody has actually proved we got steel, but my 18 has CF)
EU particulate filter (needed and used only in EU for new emissions laws and not here in NA) is big and only place to put us next to driveshaft. So driveshaft moves to steel. M3 and M4 have different wheel bases and enigine than OG M2 and OG M2 doesn't use CF driveshaft. So not same part - even the steel one. (Didn't look up in real oem, Someone else can) https://f80.bimmerpost.com/forums/sh....php?t=1411862
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist |
11-02-2018, 07:00 AM | #21 | |
1287
Rep 1,675
11-02-2018, 07:56 AM | #22 |
2543
Rep 3,968
Correct, but that is a different forum and I bet the driveshaft part is different there too
