Real trouble any help apreciated
10-30-2018, 05:31 AM | #1 |
Rep 43
So car starts fine but as soon as I put it on drive and start rolling I get a small shoulder and then almost instantly a transmission fault comes up. If I continue driving idrive goes black dashboard goes christmas tree. No electricals no speedo or signals nothing then car overheats and engine just switches off I can't accelerate at all anymore.
I suppose no water pump or anything electric working. I switch it off and starts without a problem again. Then the stories just repeats itself Faults 2A99 Crankshaft exhaust camshaft reference 2D5A monitoring engine torque limiting 2DEB power management vehicle electrical system 2DED power management closed circuit current violation 2E82 electric coolant pump cutoff 2E98 BDS message alternator missing 3100 boost pressure control deactivation CD95 message (operation, cruise control /ACC 0x194) faulty , receiver DME, transmitter DSC / SZL/ LWS/ ACC Any help greatly appreciated |
10-30-2018, 06:13 AM | #2 | |
4545
Rep 11,903
10-31-2018, 04:53 AM | #3 |
Rep 43
The car is from 2007 bought it about 2 years ago.
Not sure how old the battery is. I was thinking battery alternator or crankshaft position sensor Will get it home tomorrow and test few things |
10-31-2018, 04:55 AM | #4 |
4545
Rep 11,903
10-31-2018, 05:06 PM | #6 |
17
Rep 87
The battery is certainly the best place to start, but I would also get into the DME enclosure to see if there isnt anything physically affecting the DME, like water etc, or check to see if there is a piggy-back left over from a previous owner.
If there is a piggyback, definitely remove it as I had trouble with an old piggyback that caused all sorts of problems (especially at 120kmh on the highway!). |
11-01-2018, 02:38 AM | #7 |
Rep 43
Thanks, Blimp
I will have a look at that too. I got it home today and the RACV mechanic thinks is the alternator. Which would make sense with all the symptoms Now the question is to get a brand new one or a second hand for about 300 to 400 less than the new one. Or anyone can recommend any places that sell alternators at a reasonable price |
11-01-2018, 04:33 PM | #8 |
1495
Rep 3,148
Did the mechanic check the voltage output of the alternator? You can just replace the regulator on the back of the alternator its not a hard diy.
11-05-2018, 10:17 PM | #9 |
Rep 43
I took the car apart to get the alternator out. while doing this I realised the battery is not charging. Maybe a bad battery? Could the mechanic be this wrong and is a faulty battery not the alternator?
I'm really pissed off right now How do you check if the alternator is good? |
