BMW X3 Forum
BMW X3 Forum
      10-30-2018, 04:23 AM   #1
JensM
Germany
64
Drives: BMW X4 M40D 2019
Winter tires X4 F26/ X3 F25
Advise needed.
Got an X4 F26 30D 2015.
Need to have new winter tires - 19": 245/45 and 275/40.
Currently Pirelli Sottozero2 Runflat *marked (BMW approved).
I'm only going for premium tires and this leaves the opportunities quite limited having the size combo in mind - I can live with non-runflat.
Please note I'm located in Europe.
I have found this combo:
245/45/19: Pirelli W 240 SottoZero S2 runflat 245/45 R19 102V XL* (* = BMW approved - do only exist as runflat) @ 260Euro
275/40/19: Pirelli W 240 SottoZero S2 275/40 R19 105V XL MO (MO = Mercedes approved - this is a non-runflat) @ 194Euro
My question is: Tire pattern and technology seems same just one is runflat (front) and one is non-runflat (rear).
Will this be a problem for te Xdrive system?
- Or do I have to have same type in front and rear?
- The rear size in runflat cost hefty 431Euro each....so almost 500Euro extra...
Thanks in advance
JensM
      10-30-2018, 05:39 AM   #2
JensM
Germany
64
Originally Posted by JensM View Post
Advise needed.
Thanks in advance
JensM
Actually just found this:
https://www.lesschwab.com/article/ca...dard-ones.html
"Run-flat tires (RFTs) are built with reinforced sidewalls, which make them a lot stiffer. This is why they can be driven between 50 and 100 miles (depending on the type) at about 50 mph with low or no air.
When there's a big difference between your front and rear tires' sidewall flex, your car's handling will be imbalanced. You won't have proper stability, especially when you need it most: around corners, at highway speeds and when swerving"
Seems like a No-Go
xbimmers
