10-29-2018, 06:47 PM | #1 |
Rep 4
Front: 19x8 Rear: 19x9.5 - tire size
Hi all
I have a 2014 F30 M performance, would the following fit? 235/40/19 19x8 ET32 265/35/19 19x9.5 ET35 Using this to figure it out: http://www.rimsntires.com/specspro.jsp Not sure what to make of this? Will I rub or not? Suspension clearance: 100% clear (leaves even more room than OEM) Fenders clearance: REAR: Package 2 will stick out 17 mm (0.7'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset. FRONT: Package 2 will stick out 9 mm (0.4'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset. Wheelwells clearance: Will fill out the wheelwell by extra 4 mm. Almost no difference SPEEDOMETER: When speedometer reads 60mph (96.6km/h) actual speed will be 60.7mph (97.7km/h): 1.2% faster. THANKS! |
10-30-2018, 08:15 AM | #3 |
1272
Rep 2,960
Are you lowered at all? I'm on H&R sports with 275/30/19, 9.5et36 in the rear and not even close to rubbing
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
