TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > 2009 CIC maps update failure
      10-26-2018, 12:57 PM   #1
ceejayjay
Drives: e91 335i
Unhappy 2009 CIC maps update failure
guys
I'm really struggling to make any headway with updating my maps on my 2009 E91 335i
I've managed to get the 1B file off the car using the well described techniques on here and also generate the appropraite FSC code again using the excellent instructions on here.
My trouble is getting the car to recognise the actual maps updates themselves.
I've tried each of the following
  1. single package on single FAT32 32GB USB stick (same stick as used to retrieve 1B
  1. 3 x usb pacakges on single FAT32 32GB USB strick
when using either of the USB sticks I find that the car does not recognise the map update, and in addition seems to delete the contents of pkdbg folder!!
I also tried to burn the 3 x USB images to a dual layer DVD, I managed to burn the first DVD but the car didn't recognise the disc as an update.
can anyone suggest anything more? I'm toiling here and I really want the better maps, if I recall the car is stuck on 2010 maps as it stands
EDIT : just to add I've got the maps version with the tick and the i in the bottom left corner
any help much appreciated.
regards
CJ
      10-26-2018, 01:18 PM   #2
IllSic_Design
IllSic_Design's Avatar
2124
Drives: 09 E92 335i
You need to make sure if you do the 3 seperate files you only have the first file(s) in the root of the usb drive, and have the other two in a folder on the root. And swap them around as you make your way through the 3 files. Also, after you stick the drive in the glovebox usb slot you will probably have to hit the "options" button while viewing the nav, then scroll to the bottom of the options and if you have the right files configured correctly on the usb drive it should have a update option to click on.
      10-26-2018, 02:39 PM   #3
ceejayjay
Drives: e91 335i
thanks
files were definitely in the right place on the USB stick
dont have the update option
car is currently on the 2013 maps package.
I'm going to try a couple of different USB sticks to be honest, everything I've read points to the fact my iDrive software is at a suitable level to support USB updates.
i.e grey info panel in top right going away when clicked, and tick in info box in bottom left.
maybe its just a bad USB stick.
      10-26-2018, 02:45 PM   #4
david in germany
729
Drives: 118i, 335i and 328i
Until my 2009 lci had the CIC updated in 2015 I had the update via the 3 DL DVDs. Once it was updated I was able to update my maps via the individual USB option (each disc on an individual USB stick). Also make sure you are using the USB port in the glove box.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
Appreciate 2
      10-26-2018, 02:53 PM   #5
IllSic_Design
2124
Drives: 09 E92 335i
My 09 (09/2008 build) had original 09 maps when I updated mine to 2018-1 like 6 months ago. Took me a while to figure out how to get it going but no problem once I found the option in the options menu. I have read that sometimes the USB has to be reformatted back to FAT32 or something like that also, but idk. As long as you have the "i" and check mark you should be able to update no problem from USB.
      10-26-2018, 03:57 PM   #6
ceejayjay
Drives: e91 335i
Ok maybe a different stick might do the trick then.
I just ordered a sandisk cruzer which I've read being used on here so I'll try that and see what happens.
      10-26-2018, 04:11 PM   #7
IllSic_Design
2124
Drives: 09 E92 335i
You don't need anything special, I bought the cheapest one they had at walmart to do the trick. Sometimes after being used they might be reformatted, which is why some people say to make sure it is reformatted back to original format, which is I think is FAT32 but not sure.
      10-31-2018, 04:30 PM   #8
pelon222
13
Drives: E90 328i
How did you do it? I couldn't figure out how to do mine. Nothing happens when I put my flashdrive in the usb port.
      10-31-2018, 04:54 PM   #9
IllSic_Design
2124
Drives: 09 E92 335i
As I said in my posts above; All you should need to do is make sure the files are setup on the usb flash drive correctly, enter the flash drive into usb port in glovebox, and then press the options button while viewing the navigation, scroll to the bottom of the list and click update.
      11-27-2018, 07:14 AM   #10
MILLER335I
MILLER335I's Avatar
68
Drives: BMW E90 Dinan stage 3 335I
Hi! I had someone help me do the ssd conversion on my cic, but I cannot update the maps. No matter which version I use it fails at 40.9% or 28% or so. Any ideas? Thanks in advance!
2007 E90 335i N54 Montego blue with grey Dakota leather interior
      11-27-2018, 10:33 AM   #11
icetuto
Drives: F20
Originally Posted by ceejayjay View Post
guys
regards
CJ
im having the same problem... i have the "i" and the "tick" i managed to get my 1b file via ENETcable so i should 100% have the correct 1b file... it always says that fsc code incorrect
      11-27-2018, 11:08 AM   #12
ceejayjay
Drives: e91 335i
sods law, I've got my 1b file via the USB sticks that now won't allow me to do an update..
      11-27-2018, 12:56 PM   #13
icetuto
Drives: F20
I even contacted a guy online that i quote: "i can update every map on bmw" i explained everything i've done and no success. everything is ok inside the flash drives. it just the fsc code that doesn't work... i've checked the 1b file and everything is ok insde there (exactly 319kb) i even tried manually (goin with the enet cable and deleting the unecessary bits) i dont know what to do
I'm on europe premium 2009 premium
      11-27-2018, 02:18 PM   #14
IllSic_Design
2124
Drives: 09 E92 335i
Pay someone the $10 or so that they charge on ebay for an fsc code and be done with it if that's the issue.
      12-03-2018, 12:23 PM   #15
icetuto
Drives: F20
the thing is the guy tried with some fsc codes but none of them worked...
      12-05-2018, 02:39 PM   #16
Joe@TopGearSolutions
Joe@TopGearSolutions's Avatar
263
Drives: BMW
Is this a retro, replacement, or OEM CIC?
      04-10-2020, 08:41 PM   #17
icetuto
Drives: F20
It's OEM but good news!! Made it work! Alright so I contacted another forum, and in that forum I posted a question about this... 10 Mins later i had the FSC code for free. So apparently the car is giving me the wrong VIN number it's giving me 1234567 So I sent my actual vin by message to him and we have me the code... Looks like a hacker!
