10-25-2018, 08:52 PM | #1 |
34
Rep 165
19x9.5 et22 up front?
Looking at some new wheels and found a good deal on a set 19x9.5/19x10.5 ET22 all the way around. Will those fit up front?
Thanks guys |
10-25-2018, 09:22 PM | #2 |
3117
Rep 4,363
with appropriately sized tires and oem spec negative camber, 9.5 +22 is too aggressive. it'll poke out a decent amount and the outer shoulder of the front tire will contact the fenderwell liner while turning.
10-25-2018, 09:34 PM | #3 |
42
Rep 126
I rubbed like crazy in the rear with that size and already had -2.4 camber, lowered on H&R sports with Bilstein B8's and rolled fenders. Can't imagine that spec would work on the front without fender rolled and aggressive camber.
10-25-2018, 10:12 PM | #4 | |
1044
Rep 2,152
18x9.5 +28 square, -1.9 camber front and rear. |
kern4174453.00 |
10-25-2018, 10:38 PM | #6 | |
1044
Rep 2,152
i don't rub at all |
10-26-2018, 09:48 AM | #7 | ||
993
Rep 1,934
I suppose a 255 on a 9J would need less camber and a higher offset?
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
10-26-2018, 10:15 AM | #8 | |
1044
Rep 2,152
Put any other brand of 255/40/18 on a 9.5 and you won't see any stretch. |
10-26-2018, 11:01 AM | #9 | ||
993
Rep 1,934
It's stretched as long as the sidewall isn't on a 90* vertical plane. It may not be super stretched, or with poke, like what seems to be popular with stancing crowds, but it's still stretched. Unlike the word "aggressive" which is subjective, the word stretched is objective. I always say it's stretched when the rim of the wheel isn't completely seated in the tire. Even some oem setups implement some stretch. So don't take offense to the word is all I'm saying. Your set up is still nice guy My last car had some decent poke and a good amount of stretch, but this time around I'd like to go for the really square and seated look with no stretch at all. Cuz Racekor I've
10-26-2018, 11:22 AM | #10 | |
1044
Rep 2,152
10-26-2018, 03:33 PM | #11 |
34
Rep 165
10-29-2018, 12:13 AM | #12 |
1044
Rep 2,152
Back would require a lot of camber or stretch, fronts should be ok.
