2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing Is a wider rim always better for RE71s on a stock suspension m235i?
      10-25-2018, 04:00 PM   #1
buster-riley
24
Drives: 2016 m235i 6MT no sunroof
I am a newbie just finished my first autocross season on 225/45/17s and am will get new wheels for next year. I'd like to run 245/40/17s. Does rim width make a big difference. what rim width and ET should I buy? Thanks guys.
      10-25-2018, 04:39 PM   #2
dradernh
dradernh's Avatar
4179
Drives: 2017 M240i
Yes, it makes a difference. You want as much tread width as possible on the pavement.
17X9 is the wheel size I would recommend for a tire with the 8.6" tread width of the 245/40-17 RE-71R.
Someone else will have to chime-in regarding offset(s).
2017 M240i: 23.6K, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
      11-12-2018, 05:33 AM   #3
GasBurnlife(landapanda)
573
Drives: BMW M2
You want to go as wide as possible to maximize tired width and this the contact patch. There is a great threat on this in the M2 forum:
Max rubber on the M2? https://f87.bimmerpost.com/forums/sh....php?t=1464923
      11-12-2018, 10:35 AM   #4
cxp213
cxp213's Avatar
313
Drives: M235i
Ideally, you want to run slightly wider wheels than the tire so you get a slight stretch for maximum contact patch and less sidewall squirm. Simply bumping up the tire size without taking wheel into consideration is not smart. That said, seat time is always more valuable than anything else so if you've no funds for wheel upgrades, don't worry too much and focus on getting more practice in.
      01-04-2019, 10:10 PM   #5
goodNIGHT
goodNIGHT's Avatar
107
Drives: 2015 M235i
agree 100%. I'll also add that you get better response and feedback from this type of setup. I have run 265s and 255s on the rears and the rear axle seems more responsive when I'm running the 255s. therefore I'm more consistent with my input bc I can feel what the rear is doing more.
      01-20-2019, 11:31 PM   #6
nubbster927
64
Drives: AW M235xi
For what it's worth, I'm running 245/40/17 on 17x8 wheels and am having a ton of fun with it. Stock suspension too. Agree with the other guys that a wider wheel is ideal for this tire width, but I also like having the extra grip over the 225 mm. The stiff sidewalls on the RE71r means tire response is still great.
The reason I did this is so I could get a square setup to rotate my tires easily, since I have an xdrive.
https://www.2addicts.com/forums/show....php?t=1485848
      01-24-2019, 12:25 PM   #7
bbnks2
1207
Drives: 135i N55
Yes, re-71r are fairly soft sidewall tires. Pinch them onto too small a wheel and you will get tons of tire roll no matter how much pressure or camber you run.
Tags
re71r
Search this Thread:
Advanced Search
2addicts
