10-25-2018, 03:21 AM | #1 |
164
Rep 496
Tecnical torque BMW x2 m35i and merc a35 amg
So here's my question for you experts.
Two new cars both claimed to have 302 bhp, both claim 0-62 in about 4.9 secs. However the X2 has 450 nm and the A35 has 400 nm. Does this matter a damn - is the BMW better in some way - how does the extra 12.5% extra in nm manifest itself? Grateful for a little education if its not too much trouble. |
10-25-2018, 03:26 AM | #2 |
128
Rep 641
Lots of different factors to take into account that the raw figures just don't show.
1. Traction, 2wd, 4wd etc, 2. Weight 3. Gearing 4. Torque spread rather than just maximum torque figures And loads more |
10-25-2018, 03:28 AM | #3 |
164
Rep 496
Hells teeth I knew it wouldn't be simple. One fact - both are 4 wheel drive.
10-25-2018, 03:29 AM | #4 |
521
Rep 947
It depends on more factors (including and not necessarily in the most important order):
Weights Gear ratio How broad the rev band is for the quoted torque All things being equal the extra 12.5% torque will lead to slightly greater acceleration in each gear. Edit: Tooo slow on the keyboard! but at least we agree. Last edited by Techno 9000; 10-25-2018 at 03:31 AM.. Reason: Too slow to answer 😀 |
10-25-2018, 04:20 AM | #5 |
606
Rep 1,455
Power and torque are probably the least understood parameters
Power and torque are directly related by engine speed The specified torque is that produced at a particular engine speed, as is power The engine speed that maximum power is produced is usually much higher than maximum torque The torque at the wheels is directly influenced by gearing as well as transmission losses All the figures give you is an indication of an engine's characteristics. Looking at the torque / power curves is much more meaningful. If you look at the torque for the 328i the torque curve is almost completely flat however that's the ECU programmed that way |
10-25-2018, 04:21 AM | #6 |
1868
Rep 13,043
Drives: BMW M340I G20
Forget 0-60. It's 30 - 50 or 50-80 mph that matters.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
10-25-2018, 04:37 AM | #7 |
Barge driver
8688
Rep 12,436
Another often overlooked but most important factor, is where the torque is made and for how long does the torque last, often described as the area under the curve on a dyno plot.
As an example an M3 makes 550nm a 335d 600nm but the M3 makes that peak figure for 3650rpm the 335d for only 1000rpm hence the M3 is the more powerful faster car despite producing less peak torque. Bare torque figures give you very little info.
730d/Z4C
10-25-2018, 04:37 AM | #8 |
164
Rep 496
I think I'm getting it! so I need to wait until the full engine spec is published on both to make a comparison eg when max torque kicks in and how long it lasts etc.
You'll realise that this is not totally theoretical because I'm looking at either of these as next car. One thing I do understand is that Mercedes might shave in at under £40,000 fully equiped whereas the BMW will I guess will be at least £43,000 to my specification! Last edited by Tom Tallon; 10-25-2018 at 05:00 AM.. |
10-25-2018, 06:15 AM | #10 |
8572
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
What you ideally want is both to have a full autocar roadtest where you can see the in gear times for all the 20mph acceleration increments, as well as the 30-70 through the gears time.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
10-25-2018, 07:21 AM | #11 |
From the dark side...
40
Rep 177
BHP sells engines. Torque wins races....
2017 - M240i Vert EBII. Memory Seats, Black Leather, Pro Nav Pack, PDC, Cruise, Heated Seats, Folding Mirrors, Heated Steering Wheel, Harman Kardon, High Gloss/Pearl Chrome Trim, Convertible Comfort Pack, Speed Limit Display, EBT, Load Through, M Performance Exhaust.
10-25-2018, 07:50 AM | #13 |
Barge driver
8688
Rep 12,436
EFA.
And the ability to it lay down on the road helps too....
730d/Z4C
10-25-2018, 10:19 AM | #14 |
164
Rep 496
Thanks T. good idea - I'll start saving up now and look out for periodical when available.
10-25-2018, 10:30 AM | #15 |
1868
Rep 13,043
i tell customers Torque gets you there. BHP keeps you there.
10-25-2018, 10:30 AM | #16 |
1669
Rep 3,967
Agree, .. it's much more relevant for real world use.
Touching on the torque, .. peak torque that drops off a cliff quickly is not so important, it's better to have a flatter torque curve that doesn't drop off too quickly as the revs climb. 2 identical cars with different ecu tuning... Car A - 320bhp 660nm torque Car B - 305bhp 690nm torque Car B has a big torque peak of 690nm low down but it drops off quickly higher up the rev range hence it makes a maximum of 305bhp Car A doesn't produce as much torque low down but has a flatter curve and holds onto the torque better higher up the rev range, hence it makes a higher maximum bhp than Car B does. I wager that Car A is quicker if your in the right gear at the right time! |
10-25-2018, 10:32 AM | #17 | |
1868
Rep 13,043
