Occasional puff of smoke?
10-22-2018, 10:10 AM | #1 |
298
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
Hi all,
I am having this occasional puff of smoke, and I mean plenty of white smoke coming out of the exhaust at times. My wife said - as she drove it more lately - that it drops a big fart Most likely to happen if engine is idling away for long time, in heavy traffic, and it won't happen more than once a day. Sometimes it happens when you start up, then clears in a few seconds. It never smokes on high load, pushing it or anything like that. I had the downpipes out (when I changed them ) and turbos looked ok, dry, no sign of oil, and there was very little play in the wastegate. I am 100% it is oil , no coolant. Coolant level is at max every since I changed the water pump and thermostat. I have to top off about 1/2 quart in 2000 miles, so oil consumption is not too bad, but what it is, that's where it goes , in the exhaust . Is it possible for the emission valve in the valve cover to go bad? I changed the pcv valve with a new one, Rob's, but no change. Many thanks for any input. |
10-22-2018, 01:31 PM | #2 |
312
Rep 404
If its at startup then goes away it CAN be valve guides. try down shifting on your deceleration not enough to make the car slow down, but matching the speed and see if you get more smoke. This would lead me to turbo seal/s.
Clean hot side with your downpipes off doesnt always mean the seals are good. Just means the oil burned off before you can see it.
Mods related to trouble shooting posts: Stock Turbos, MHD OTS V7 stage 2+ 93 oct, VRSF Downpipes, VRSF Relocated inlets, CTS Turbo 7" Intercooler, Tial BOV with upgraded line 5.56mm, index 12 injectors, A/T OEM Flash.
10-22-2018, 02:18 PM | #3 | |
298
Rep 650
No smoke on deceleration, and no smoke on accelerating hard. Compression is a pretty even 160-162 across all pistons... I have to add I have no secondary cats, but it still seems excessive when it happens. I will try to get a new Valve Cover and gasket, it's never been replaced and I see some oil leaks on the side... That, with the new PCV valve should rule out any crank ventilation issues. From there on, it can only be turbos. Thanks |
10-23-2018, 09:06 AM | #4 |
391
Rep 532
Mine has been doing this for 2+ years since I went FBO (also have RB PCV) and catless mids. I have had nothing but clean logs and the car runs great with no visible leaks, so i don't worry too much about it. I just chalk it up to typical N54 ownership.
torrque297.50 |
10-23-2018, 10:14 AM | #5 | |
298
Rep 650
Thank you. |
10-23-2018, 12:49 PM | #6 | |
Guest
Rep n/a
Drives:
I've experienced a similar issue ONLY when running the MHD wastegate rattle fix. I would get puffs of smoke in traffic, only during/after coming to a stop when easy cruising, etc. Otherwise the car has zero issues and only burns 1 qt of oil every 10K miles.
Only reason why I tried the WG rattle fix to begin with was to see if the exhaust was any louder with the fix enabled. My WGs are naturally rattle free and the only time they rattled was when the fix was enabled lol More info: VC has about ~40k miles on it. The PCV system is well maintained and I run both high side and low side catch cans. Both WGs were properly adjusted when adding DPs ~20K miles ago. There was a thread over on the other forum that explained a reasonable theory as to why this phenomena may occur...perfectly plausible IMO, especially given my circumstances, use case, and subsequent results: Quote:
torrque297.50 |
10-23-2018, 04:35 PM | #7 |
298
Rep 650
In my case it happened before it was tuned, and to lesser extent before I removed my secondary cats. After secondary cats removal, it seems excessive now Which is normal in a way...
10-23-2018, 05:38 PM | #9 |
391
Rep 532
