10-21-2018, 03:30 PM | #1 |
Rep 19
Name that part??
Hello all,
I've just bought a 2014 228i M Sport and joined the 2Addicts forum. I sold my 135i Coupe for a 2 series as i was looking for something a little less boy-racer! After I picked up my car from the lot and had a good lock at it i found lying in the glovebox a part that I can't find where it came from. It is definitely BMW as it has a stamp. Obviously it presses in somewhere as it has a ring clip at the back. Anyone know what this is and where it came from (attempted photos uploaded)? Cheers. |
10-22-2018, 09:34 PM | #5 |
Arsevader
36
Rep 128
Yes it covers the hub nut. You can't replace it without taking off the wheel though, it won't fit through the centre hole of the wheel. However I would pry off the centre caps to see which hub it comes from (if it's even missing) before pulling wheels.
10-22-2018, 11:55 PM | #6 |
Car Geek
3626
Rep 3,594
If you don’t want to lever the centre cap off as the gap is quite tight to the wheel and it is easy to damage the finish, I’ve normally been successful in pulling the cap off using a rolled up piece of duct tape or blob of butyl tape to quickly yank the cap off.
10-23-2018, 10:02 AM | #7 |
Arsevader
36
Rep 128
Yes, or you could not listen to your son that one is loose when changing to your winter wheels and it will just fall off and get lost pretty much as soon as you go for a test drive...
10-23-2018, 06:43 PM | #8 |
97
Rep 145
To remove my wheel center caps (when I take the car to the track) I keep a small window suction cup on the trunk. Push the suction cup and pull, off goes the center cap.
10-24-2018, 08:51 PM | #9 |
Rep 19
Thanks everyone for the advice. I'm wondering what the point of covering the Hub nut is? I'm sure BMW wouldn't add parts that they didn't need to. Anyway, I'll have a go at pulling the centre caps off to find out which wheel is the culprit.
I remember when I had to pull the wheels off my old 135i the nuts were torqued so high that I needed to use a 3 meter metal pipe as leverage. Why do tyre companies need to do the nuts up soo tight. hopefully the 228i isn't that bad. |
10-24-2018, 09:07 PM | #10 | |
987
Rep 1,241
CP911
BM235iW97.00 |
10-25-2018, 12:31 PM | #11 | |
4413
Rep 3,497
https://www.ecstuning.com/b-genuine-...h/71126769683/ This is the same unit shown on realoem at: https://www.realoem.com/bmw/enUS/par...&q=71126769683 The Heyco-branded torque wrench comes with a standard length 17mm socket.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
BM235iW97.00 |
10-25-2018, 05:36 PM | #12 | |
987
Rep 1,241
CP911
10-25-2018, 05:53 PM | #13 |
4413
Rep 3,497
Yes and yes, you can. That's how I'm using it on my wheel stud-equipped car.
