The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 5 or 7in intercooler with only bolt ons?
      10-20-2018, 07:16 PM   #1
Occ224
13
Drives: 2007 E92 328i
Should I upgrade to a 5 or 7 inch intercooler when I'm only going to do exhaust and air intake mods? I will not be upgrading the turbos unless i need new ones. Any idea?
Plan is dps, intercooler, charge pipe, inlets and dci
      10-20-2018, 07:59 PM   #2
Bimmer_Engineer
Bimmer_Engineer's Avatar
1044
Drives: 2007 335i
I have a g plus 5” stepped intercooler from eBay...$215 shipped and install wasn’t bad. Very pleased with IATs...
Just to clarify what I was thinking here...if you’re not going to do a tune (which you don’t have listed) then a 5” is probably adequate...
      10-20-2018, 10:47 PM   #3
addictedtoboost
110
Drives: 2008 335xi E92
I'd go with a 7" VSRF FMIC personally.
      10-21-2018, 12:38 AM   #4
hellokitty
hellokitty's Avatar
2896
Drives: '17 M3 ZCP DCT
Second this. No reason not to use the most efficient IC you can afford. I’d get the HD core as well.
The_Werm212.00
      10-21-2018, 01:35 AM   #5
JoeyH335i
JoeyH335i's Avatar
87
Drives: 2009 BMW 335i
It would depend on if you will run a stock charge pipe or not. If you want to do mostly a stock pipe connection, I would say a 5 inch.
I went with ARM 5 inch stepped FMIC.
I am just here to help!
      10-21-2018, 07:35 AM   #6
Occ224
13
How much better is the 5 compared to 7? Is it worth the money when all im doing are bolt ons? I Will be doing a tune
      10-21-2018, 08:47 AM   #7
hellokitty
hellokitty's Avatar
2896
I would think the majority of people are running 7". The difference will be apparent in logs especially during the summer and especially if you do multi gear pulls.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      10-21-2018, 02:16 PM   #8
snedanator
97
Drives: e93 335i le mans blue
Defo go at least a 7 inch especially since it sounds like ur going for a custom tune? Hence why ur adding inlets?
      10-21-2018, 08:37 PM   #9
Chris@VargasTurboTech
1933
Drives: All Things TurboCharged
Minimum 7" HD version IMO.
      10-22-2018, 10:23 AM   #10
FCobra94
Guest
n/a
Drives:
OP lives in FL...7" for sure.
Appreciate 3
      10-22-2018, 01:43 PM   #11
b92
b92's Avatar
540
Drives: E92 335is, 6MT
5" vs 7" isn't even much of a question anymore because the difference in cost is minimal. It's more of 7" vs anything bigger.
FBO living in FL? I wouldn't consider anything smaller than 7".
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon.
      10-22-2018, 01:48 PM   #12
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
7" all day
      10-22-2018, 02:17 PM   #13
tisdrew
98
Drives: 2009 335i
A 5" likely requires no cutting of the shroud whereas a 7" almost certain will so the install of the 5" if you're a DIYer is significantly easier.
That being said, from a performance standpoint, a 7" is a significant difference and what I would personally recommend. On my stock turbos with inlets and ethanol maps, the ETS 7" was JUST enough but I could've gone bigger imo; when custom tuning it was the next bottleneck after HPFP. I'm actually looking to sell it and get a 1000hp intercooler for my new power goals. PM me OP if you're interested in a used option
"Wheels and exhaust aren't a build"
      10-23-2018, 08:07 AM   #14
wrrush
24
Drives: 2007 335xi
it depends on your goals, if you are just trying to stay bolt on and thats it the 5 should be ok but if your getting larger turbos, upgrading all fuel options ect or building out your engine and trans and racing all the time, then i would say 7. but it will never hurt performance to go 7
      10-23-2018, 11:01 AM   #15
TemjinX2
521
Drives: 2008 335xi e92
just wait till black friday and get just get the 7inch vrsf intercooler. Usually with their black friday discount is only a $80 difference between the 5inch and 7inch or you can wait till theirs the next ebay coupon. For only $80 more i think its worth it in terms of performance difference.
      10-23-2018, 11:20 AM   #16
torrque
298
Drives: Ferrari F430, E92 M3, 335xi
2005 Ferrari F430  [9.08]
2009 BMW M3  [10.00]
2008 BMW 335xi  [0.00]
I did a 7" with no exhaust mods (just no secondary cats) and I am happy as Larry. I would not bother to be honest to go 5".
      10-23-2018, 11:46 AM   #17
teknic90
teknic90's Avatar
99
Drives: G20 M340i
2020 G20 M340i  [0.00]
2016 BMW 340i  [0.00]
Did you do your install with floor jacks like this??!!
      10-23-2018, 12:06 PM   #18
JoeyH335i
JoeyH335i's Avatar
87
Yup. lol
Unsafe as all Fük!
      10-23-2018, 06:15 PM   #19
Torgus
Slow.
Torgus's Avatar
3782
Drives: Single Turbo N54 on Meth!
2007 BMW E92  [10.00]
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
I have a helix ic for sale if you want one of the best designed ICs.
Given a fmic can only cool to ambient temperatures you will need either a massive fmic or want to use meth or e85 given Florida temperatures.
An intercooler can only do so much. It is a heat sink at the end of the day the larger and more mass the better.
      10-24-2018, 03:15 PM   #20
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
Do you plan on tracking the car or just open on increasing your HP & drive in a spirited manner?
Track = 7" for sure
      10-24-2018, 04:36 PM   #21
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
24198
Drives: 07-335/12-328/18-M4/21-M4CP
7" in most cases, 7" HD if you are running over 400 whp.
Only time i recommed 5" over 7" would be if you live in a cold area all year long and you are running stage 1 tune with no other modification
https://x-ph.com/sale/
Phone number 702-494-9435
Appreciate 2
      10-24-2018, 09:28 PM   #22
1933
Don't forget if you want to be disappointed by a FMIC upgrade... then 5" is 100% the way to go. lol
Appreciate 2
b92539.50
