Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Is this a rod bearing? (Audio files attached)
      10-18-2018, 12:58 AM   #1
JonEQuest
JonEQuest's Avatar
246
Drives: 2008 335i Convertible 2007 335
I think I may have a bad bearing. These two audio files were recorded on my phone laying on the ground directly under the oil pan while the car was on jack stands.
1st file: This was the car idling. I hear a metallic sound or some sort.
https://drive.google.com/file/d/1v9b...ew?usp=sharing
2nd file: This is with me revving it up after addling for a few seconds. I went up to about 3,000rpm. Then revved it to about 1,500 or so toward the end.
https://drive.google.com/file/d/1Prh...ew?usp=sharing
      10-18-2018, 06:59 AM   #2
Boland01
149
Drives: 2010 535ix, 2008, 2007 335i
No. When our old E36 threw the rod bearings you could here them from a block away. Sounds like the normal BMW ticking to me.
      10-18-2018, 07:35 AM   #3
JonEQuest
JonEQuest's Avatar
246
Really? They sound like this? I hear sort of a chirp in there too. It is more pronounced under the car than on top. Above the car at idle you can't it hear it much, but when you rev the motor something significant seems to be there.
      10-18-2018, 02:41 PM   #4
Faredo
Faredo's Avatar
312
Drives: 335i
sounds like loud injectors to me. Mine could be heard outside of the car or in the cabin. dealer replaced them under warranty and they are much quieter.
Are you using the acoustic cover over your valve cover?
Mods related to trouble shooting posts: Stock Turbos, MHD OTS V7 stage 2+ 93 oct, VRSF Downpipes, VRSF Relocated inlets, CTS Turbo 7" Intercooler, Tial BOV with upgraded line 5.56mm, index 12 injectors, A/T OEM Flash.
      10-18-2018, 02:47 PM   #5
JonEQuest
JonEQuest's Avatar
246
Yes, it is also louder under the car near the engine. That is where the phone was recording the sound from.
      10-18-2018, 02:50 PM   #6
9krpmrx8
Clean is the new cool, keep it that way.
9krpmrx8's Avatar
808
Drives: 11' Alpine White 335i Sedan
Sounds normal to me. Very common issue for people to think there is a problem. Welcome to direct injection.
If you want to know if you have a rod bearing issue, spend $28.00 and send an oil sample to black-stone laboratories
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive
      10-18-2018, 02:56 PM   #7
JonEQuest
JonEQuest's Avatar
246
I don't know if the sound isn't coming across well in the recording but it is loud and like nails on a chalkboard. If I were at a BMW dealer and the car was a CPO with 5,000 miles and sounds like this I would still walk away. My neighbor has a 2016 328i and he has no loud chirping/clanking engine sound. I know about the injector sound. It gets twice as loud when the sound cover is off and sounds like a loud sewing machine. This is different than that.
https://drive.google.com/open?id=1Vd...Q5xGI7cKopZm9P
Now I am second guessing myself. Maybe I will get lucky. I would LOVE for it to be an injector.
      10-18-2018, 03:43 PM   #8
9krpmrx8
9krpmrx8's Avatar
808
It sounds completely normal. About once a week someone posts up a similar video freaking out. But like I said, test the oil. Or do a compression test, etc.
2015 X5 35i Xdrive
      10-18-2018, 03:45 PM   #9
9krpmrx8
9krpmrx8's Avatar
808
This is mine, 98,000 miles and counting, zero issues running to 22+psi.
2015 X5 35i Xdrive
      10-18-2018, 03:49 PM   #10
JonEQuest
JonEQuest's Avatar
246
I am going crazy. It actually sounds a bit better now. I was trying to unplug injectors one at a time to see if there was a dramatic change and didn't see a big change for any particular injector but I did get a loud whistling sound when I unplugged injector #3. The car also ran really rough even after making sure all were plugged back in. I plugged all back in. Turned off the key, then started the car back up and it ran fine again. BUT I did notice a bunch of oily liquid in injector #3's electrical connector. I brayed it out with brake cleaner then dried out the hole, then plugged the injector back in. I don't know if the noise is less or I just want it to be better but it does sound a little better. I am knowledgeable about electronics and I normally would not think oil would be conductive enough to cause problems but maybe that was it? From my drivers seat it is a noisy engine but does not seem to have as much of the death rattle as before. I guess I need to put it back together and drive it to see it under load. P.S. I do get frequent injector #3 misfire errors. I wish I could pull injectors to look but I have heard that the O-rings need to be replaced anytime you pull them.
      10-18-2018, 03:55 PM   #11
JonEQuest
JonEQuest's Avatar
246
I am on my 4th oil change since buying the car. I did 3 changes in 6 weeks. The first was just cheap synthetic oil to flush, then one with Marvel Mystery oil for one oil change, then 2 bottles of Rislone on another oil change to clean the engine since I thought I had a bad lifter. After replacing all 24 lifters I put fresh Mobil 1 Euro oil in it with new spark plugs. I know the oil is OK now and would probably not have enough traces of old bearing left if I tested it. Also, I thought a compression test would still show good even if you have a bad bearing?
      10-18-2018, 03:59 PM   #12
IllSic_Design
IllSic_Design's Avatar
2124
Drives: 09 E92 335i
BMW engines, and the N54 especially are REALLY noisy engines. Like said, do an oil analysis to check for failing bearings.
      10-18-2018, 04:46 PM   #13
9krpmrx8
9krpmrx8's Avatar
808
A compression test would not show a bad bearing. And never use Marvel again, it's mostly solvent in mineral oil, it's very bad for your engine. No additives are needed, ever.
2015 X5 35i Xdrive
      10-18-2018, 04:47 PM   #14
JonEQuest
JonEQuest's Avatar
246
A compression test would not show a bad bearing. And never use Marvel again, it's mostly solvent in mineral oil, it's very bad for you engine.
MM oil was just for flushing and cleaning. I am not driving the car yet since it is a project and has no tags yet.
      10-18-2018, 04:50 PM   #15
9krpmrx8
9krpmrx8's Avatar
808
Yeah it's still bad though, it is not proper engine oil and the solvents will dilute the oil, it's just useless. Good synthetic oil is all you need.
2015 X5 35i Xdrive
      10-18-2018, 04:58 PM   #16
JonEQuest
JonEQuest's Avatar
246
I was cleaning the engine. I have just Mobil 1 Euro synthetic in it now.
