10-16-2018, 02:40 PM | #1 |
24
Rep 116
Preventative Maintenance For Our Cars
Hey guys was just wondering what is some preventative maintenance you do for our cars? are there any common issues that can be avoided by regular maintenance? Had my car for about 10 months now, put 12k miles on it and have done an oil change half way thru, about to do another oil change and brakes soon but was wondering what other people do.
10-16-2018, 02:48 PM | #2 |
3076
Rep 5,577
Brake fluid - every six months you can siphon fluid out of the reservoir and add fresh fluid, and do flush every two years.
Windshield wiper blades - yearly Cabin filter Intake filter and air box vacuum out Lubricate weather stripping with appropriate product. Tire pressure and tire inspection. Check trunk floor for moisture. |
10-16-2018, 04:11 PM | #4 |
174
Rep 400
For M235, there are couple of things you can do.
Replace water pump at 50k miles. Regular inspection for oil cooler leakage. Upgrade charge pipe. Check for coolant bottle for any leak. Inspect valve cover oil leak. |
10-16-2018, 08:24 PM | #6 | |
77
Rep 369
EEBreh122.50 |
10-17-2018, 02:45 PM | #7 | |
225
Rep 610
If you just plan to get rid of the car when it hits 50k then just follow the BMW schedule. Otherwise spend a a few bucks to do some real maintenance. |
10-17-2018, 08:11 PM | #8 | |
809
Rep 1,369
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
10-18-2018, 03:57 PM | #9 |
445
Rep 1,264
Our cars are typically turbocharged so I highly recommend that you change the oil and filter every 5000 miles. This is what I use for oil:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 It's BMW LL01 FE qualified and it's a lot cheaper than the stuff at the dealer. Also, its base stock is class 4. What does that mean? A bit of info: the B58 engine (M240i engine) uses 0W-30 synthetic oil everywhere in the world except the USA. Why? Mileage standards. Class 1 and Class 2 oils: made from crude from the earth; not synthetic. Class 3 oil: made from crude form the earth; synthetic (YUP)* Class 4: made from synthesized polymer chains (aka "PAO"). Class 5: same as class 4 but the polymers are different (Redline oils are class 5). Almost all consumer synthetic oils are made of class 3 stock. * Class 3 base stock is made from oil from the earth. The crude is broken down farther than class 1 and class 2 oils. The class 3 base stock is then synthesized from the polymers. |
10-20-2018, 12:40 PM | #10 | |
4413
Rep 3,497
I also have an Alternative Maintenance Schedule of Mike's that is worth reading through as well. I'm sure he'll send that out if he's asked for it.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
