Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Normal 335i Operating Oil Temp?
      10-14-2018, 08:17 PM   #1
e92bimmer184k
Drives: 2007 BMW 335i Coupe
Lightbulb Normal 335i Operating Oil Temp?
I have a 2007 BMW 335i Coupe with Dual Cone Intakes, blow off valve, and a strage 1 MHD tune. Automatic with 60,000 miles
The cars oil temperature has been around 230-245 lately and it seems a bit high. Does anyone know the normal operating temperature of the car?
      10-14-2018, 09:04 PM   #2
BM3Rrrr
Davy Jones, Giant Squid
BM3Rrrr's Avatar
No_Country
271
Drives: a Pirate Ship
That's normal... mine usually sits around 230 unless I flog it then goes up to 245.
2010 e90 335i LCI - xHP - Mishimoto - BMS - CPe - Turbosmart - MHD - Eibach - Koni - VMR - LUX
      10-15-2018, 09:10 AM   #3
tony55343
104
Drives: 08 335i coupe 6mt
anywhere between 230-250 is normal .
      10-15-2018, 12:47 PM   #4
Jklad
Jklad's Avatar
421
Drives: 2007 335i Coupe
Normal
2007 E92 335i MT
      10-16-2018, 05:21 PM   #5
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
~238 is the factory oil cooler thermostat. These cars hover in that area with or without oil coolers.
      10-17-2018, 12:18 AM   #6
Chris@VargasTurboTech
1933
Drives: All Things TurboCharged
230-250 as stated above. That dropped a bit when I added the CSF radiator.
      10-26-2018, 07:36 AM   #7
335e92tx
ahat
335e92tx's Avatar
1036
Drives: Was '07-335e92 - Now '13-335IS
That I have seen motul has slightly lower oil temps than most others.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos.
https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8
      10-28-2018, 09:05 PM   #8
rgfinn76
47
Drives: 2008 335i Sport Coupe
Ive been using Liquid MolyGen and mines around 220f. Before the MolyGen is was around 230f
      10-31-2018, 12:42 AM   #9
Rogue-OP
Rogue-OP's Avatar
58
Drives: to Drum & Bass
Did you have to code anything to notice a difference? My CSF didn’t change the temp.
      11-05-2018, 03:23 PM   #10
srbarnes4ever
26
Drives: 07 335i E90 Sport
My CSF definitely has dropped avg oil temps, particularly at highway speeds. I am also running MHD set for Sport cooling.
07 335 E90 - MHD Stage 2+FMIC (Black)
11 X5 - MHD Stage 1+FMIC (Sapphire Black Metallic)
20 M340i X-Drive (Alpine White)
      11-05-2018, 05:28 PM   #11
RSL
647
Drives: E92 ///M3 (Retired) / 335is
Sport cooling has way more impact than swapping the radiator ever will. BMW targets the engine to run hot on purpose, it's not so much a capacity issue. They can run very cool ECT/OCT on stock hardware simply by changing a few tables in the rom, just like the MHD check boxes do.
An aftermarket radiator by itself will do almost nothing for temps (unless you count take longer to warm up). A better radiator only increases the efficiency/capacity that could be exchanged, the thermostat/DME have the final say/control of how much actually is exchanged.
