Free Dyno
10-13-2018, 11:15 AM | #1 |
Rep 35
Free Dyno
Here is a free promotional code for Log Dyno on the Google Play store:
7NUDNYUX1L8QRUUHNWHLXZA You can measure Torque and Horsepower from your MHD, JB4 or any CSV datalog on your android device in seconds. Log Dyno has been compared to multiple Dynojet measurements and the results were spot on. Link to Log Dyno on Google Play Features: -Once your car is set up (Can save multiple cars, set up is only required the first time), measuring your car from your datalog takes only seconds. -After opening your log, if your data log is a recent one, you can just hit auto-weather, and environmental values will be automatically filled in for the correction factor. If it is an older log, you can just fill the values in manually. -Measurements can be viewed in lbft/nm and whp/bhp. -Measurements can be shared via email or any social network. -Measurements can be saved and loaded later without the need of the data log. Adjustments can also be made later. Log Dyno's own social network is coming soon, where you can share your measurements from the app, and specify your mods, so people who are wondering what power is possible with certain mods, tunes, now will be able to see for themselves. I will be giving away a couple more free codes to the followers of Log Dyno Facebook page. Log Dyno Facebook Page If you have any questions or need help setting up your measurement, feel free to contact: profisoftgames@gmail.com or join the Log Dyno Support Facebook group |
10-13-2018, 12:59 PM | #2 |
72
Rep 202
Well thanks, I gave it a try with my MHD logs and came at similar results as vritualdyno results on smoothing 5.
FBO mods in signature, 420-430WHP. Very user friendly and no bugs detected. Maybe a bit pricey if you need to buy it, but it was free now.
____________________________________________
2007 BMW E92 335i 6MT lightweight - OS GIKEN Superlock LSD - FBO STAGE 2+ ETHANOL - TRACK/DRIFT/NÜRBURGRING |
10-13-2018, 01:03 PM | #3 |
Rep 35
Maybe smoothing is too high and it smoothes out the details in the curve, you could also try adjusting Data RPM Step while keeping smoothing on 3. Or try maximum smoothing with low Data rpm step.
10-14-2018, 10:28 AM | #6 | |
Rep 35
If you have questions I can support you via email: profisoftgames@gmail.com |
