Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > HELP! Can't install FMIC
      10-12-2018, 11:32 PM   #1
PNWM40i
93
Drives: G01 X3 M40i MHD+XHP Stg 2/3
So I just got a 7" ARM FMIC in the mail today and what I thought was going to be a quick 1 hour install has turned into a hair pulling 5 hour mess. So I trimmed the bumper, lined everything up and I swear the pipe is less than half an inch from being tight and snug into the intercooler. It's so close yet there's still a ton of play in the pipe and obviously it leaks a ton if I start the car up. I have an aftermarket charge pipe but the lower pipes are still stock. Am I stupid or missing something? I've been messing with this pipe for hours and it's just barely short of making it even though it's supposed to work with stock connections. It seems all the install guides I checked out it just slides in with a breeze, I'm not sure if I didn't cut something or I'm not doing something right but I can't believe this is taking so long, see pictures attached for how close it is I've pushed the intercooler up and back as hard as I can and it just won't go anymore
View post on imgur.com
      10-12-2018, 11:39 PM   #2
AandSC
34
Drives: 2009 335i M-Sport MT
I had a similar problem when I reinstalled my stock IC after rebuilding my turbos. Was extremely tough getting the passenger side reconnected but I just kept working it (wiggling and pushing) and it finally reseated all the way.
2009 335i Coupe M-Sport MT 136,000 miles
2013 Mini JCW 16,000 miles
2000 Lexus LS400 82,000 miles
      10-13-2018, 02:26 PM   #3
PNWM40i
93
yeah, still no luck, might try trimming some more plastic back
      10-13-2018, 03:17 PM   #4
Krazyk
Drives: E92 335i
I had the exact same issue when I bought mine. It's due to the seals on the charge pipes but they are necessary so they don't leak...... honestly just keep trying I layed under my car for a couple hours just staring at it until I finally moved it the right way and finally slipped on. It was by no means easy but did end up fitting the way it was supposed to
      10-13-2018, 03:27 PM   #5
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
Same issue here when I had mine, the stock connections are SHIT for that intercooler. The intercooler is junk too. Took like 45 mins you have to twist and push in to get them to sit snug. With my setup I didn't trust their intercooler so I went and got the VRSF 7.5" race fmic, best decision yet for my car.
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
      10-13-2018, 03:56 PM   #6
PNWM40i
93
I honestly regret buying the ARM FMIC I wish I had dropped the $125 extra and gotten the VRSF one since they give you couplers, I think its too late to return mine though since it's all scratched up from trying to wiggle it in there. Might just bite the bullet and buy the FMIC hose upgrade from ARM or try the FMIC install kit that VRSF sells, don't see why it wouldnt fit the ARM intercooler, the fittings are all pretty much the same
      10-13-2018, 04:09 PM   #7
WeekendWarriorz
670
Drives: 2006 Z4M
Just sell that POS and get a VRSF unit. I did the same thing and got the hoses and they're even worse than the intercooler. The VRSF fittings won't fit into the arm FMIC since the inlet/outlet is so wide that the stock junk connectors can fit into it. Yeah you'll take a loss on the intercooler if you sell it but better than nothing. Or contact Jacob from ARM and tell him you hate the fitment and ask if it's possible to return it. VRSF FMIC ftw hands down.
      10-16-2018, 01:35 AM   #8
PNWM40i
93
so I decided to try and return the ARM FMIC, they keep trying to blow me off saying they'll call me back when they never will so I filed a chargeback dispute with my bank, for now I ordered a VRSF 7" FMIC, so excited!
Appreciate 3
      10-16-2018, 10:04 AM   #9
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
You're better off the VRSF. Better quality core, performance and fitment.
      10-16-2018, 04:25 PM   #10
PNWM40i
93
Yep, can't wait for it, ARM called me back and said they're going to send me the $100 hose upgrade free of charge, I'll probably just resell it on here with the hose and try to break even.
      10-18-2018, 04:53 PM   #11
malgyver
16
Drives: 2008 335i Sedan
I've also found that sitting and staring at some fitment issue for hours will produce the desired results. Lots of times, the struggle is in taking something apart. I've generally found that assembly takes a fraction of the time of disassembly and prep/cleaning.
JB4, DPs, Style 313 wheels, M-Sport front bumper, Inlets, DCI
      10-18-2018, 05:03 PM   #12
IllSic_Design
IllSic_Design's Avatar
2124
Drives: 09 E92 335i
They should reach the intercooler fine as long as the i.c. is fit up against the radiator/core support all the way. I have no issue with the connections reaching the intercooler and they also slide right into the intercooler with no issues.
      11-02-2018, 09:03 AM   #13
rgfinn76
47
Drives: 2008 335i Sport Coupe
Yep super pissed!!!! Spent three damn hours trying to get my stock Intercooler pipes connected to this damn POS from Arm!!! I called it quits at 1am and put the stock back in!!!! I’m calling ARM as soon as they open!! Only way to get this installed is to get their hose upgrade!!!
Appreciate 2
      11-02-2018, 01:53 PM   #14
PNWM40i
93
Yeah, after a few hours I stopped too. I just bit the bullets and bought the VRSF one. I bugged ARM and they sent me the hose upgrade for free after threatening them with a chargeback. I've resold the FMIC and hose upgrade on here since then. I regret cheaping out and not getting the VRSF first.
      11-02-2018, 02:25 PM   #15
WeekendWarriorz
670
Drives: 2006 Z4M
Don't get their stupid hose upgrade it's crap. I had it on my car... now my sig says VRSF 7.5 in which is the best/biggest intercooler in the market. And yes the intercooler is worth the huge amount of money, don't cheap out. Cheap people end up paying more
      11-02-2018, 11:32 PM   #16
shreedamin
14
Drives: BSM 335i E92
Hey, I had this ARM intercooler and I had a very similar problem. I ended up taking my car to the shop and we used this air grind tool to grind some of the metal from the inside of the intercooler openings. I felt like it was physically blocking the intake hose to go in further in my case. I had a very hard time clipping intercooler hose in still. But the way my mechanic and I got the couplings to fit was by taking 2 pry bars and putting them on the lip of the intercooler coupling hose and applying even pressure to both sides allowing it to "click" in.
https://www.e90post.com/forums/showthread.php?t=1513233
      11-03-2018, 08:10 AM   #17
rgfinn76
47
Originally Posted by kens View Post
Before you stop trying I had this same problem, It was a little angular piece of plastic
Drop the FMIC out of the way and look up and under that section of the corner on the vehicle. You will see what I am talking about and it will click immediately.
I just clipped it off and all fit perfect after that.
You had the ARM intercooler? How does this plastic piece effect the connection?
      11-03-2018, 08:12 AM   #18
rgfinn76
47
Im giving it one more shot today, if this doesn't go in I'm buying a VRSF... Should of did this from the beginning..
      11-04-2018, 07:04 AM   #19
rgfinn76
47
Tiago is your 5” stepped street N54 (the new version) in stock ready to ship?
I’m returning this garbage from ARM and getting my money back.
      11-04-2018, 02:18 PM   #20
WeekendWarriorz
670
Drives: 2006 Z4M
Originally Posted by Tiago@VRSF View Post
Yes sir, they are in stock and ready to ship!
+1, VRSF 7.5 race is the best intercooler on the market but does require extra cutting/bumper removal. Plus VRSF has good deals and at least you know you're using something that other people are using and pushing hard on this platform. I haven't see an ARM FMIC on an upgraded turbo car and if I did then that person is an idiot for running a stock connection intercooler. I got lucky with their chargepipe but will replace it eventually.
      11-04-2018, 04:01 PM   #21
rgfinn76
47
Ordered!!! Please ship as soon as possible man, so I can get this stocker ripped back out.
How come the newer N55 is almost $70 cheaper? Different style?
      11-04-2018, 05:24 PM   #22
rgfinn76
47
Thanks for your support, we greatly appreciate it!
The E90/E92 have a lot of extra included accessories in comparison
