BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Coding Success via ESYS on F90
      10-12-2018, 07:44 PM   #1
slavearm
226
Drives: 2019 M5CE MBB/SS
So far what I know, have completed successfully, and learned along the way:
1. when connecting to the car, use F10 profile from launcher
2. to enable video in motion in the HU_NBT2
  • VIDEO_HANDBRAKE set to: nicht_aktiv
  • API_USB_VIDEO set to: both
  • VIDEO_FRONT_LOCKED set to: nicht_aktiv
  • VIDEO_SPEEDLOCK_CONDITION set to: none=00
  • ENT_CODEC_XVID set to: aktiv
  • ENT_CODEC_XVCD set to: aktiv
  • SPEEDLOCK_FREISCHALTMENU set to:aktiv
  • Now code FDL, then wait for HU reboot
  • Press and hold up on your iDrive Controller. Then press media. This will pop up speedlock configuration menu
  • Select the second option for determining speedlock (bottom)
  • Accept that this is "for testing purposes only, and only for this key"
  • Done
3. Remove annoying disclaimers:
  • LEGAL_DISCLAIMER_TIME set to: kein_ld
  • MACRO_CAM_LEGALDISCLAIMER set to: kein_ld
  • MACRO_NVICAM_LDISCLAIMER set to: kein_ld
This is all I have messed with so far, but feel free to post up your codes and I will keep them here.
Appreciate 3
      11-10-2018, 04:12 AM   #2
Almaretto
Almaretto's Avatar
2373
Drives: Test Vehicles
S15A Connection Target
  • Close Windows & Fold Mirrors with CA & keyFob
  • Adjust Initiation Delay
  • Disable Window Safety
  • Adjust Passenger mirror Vertical Tilt when in reverse
  • Adjust Specialty KeyFOB settings
  • Close trunk KeyFOB/ Rockerswitch & remove beeps
  • Disable Horn Honk when closing vehicle with Engine ‘ON’
  • Set Default Driving Mode
  • Pressing HVAC ‘AUTO’ button does not activate A/C
  • Setting Heat/Cooling/Massage Memory for Seats/Steering wheel
  • Auto-Activate Hazard Warning System
  • EU Brake Force Display
  • Disable Welcome BMW Sound (3 Gongs)
  • Remove Seatbelt Auditory Chime / Cluster status
  • Disable OBD Alarm
  • Enables Rear Camera Zoom
  • Disables 1st fuel warning at 50 miles
  • Disable Interior Alarm Sensor (Good if travel with active pets)
  • Enable Fog lights with Parking Lights or High Beams
  • Adjust Rain / Headlight Sensor Sensitivity
  • Variable Light Distribution (VLD) & NGHB
  • Adjust Angel Eye Brightness
  • Disable Amber sidemarker lights
  • Bluetooth Pairing display at any speed
  • Disable Office Function Speedlock
  • Enable Call Log Timestamp
  • Enable Personal Ringtone over vehicle speakers
  • Video playback from USB
  • Video in Motion
  • Disable Volume Popup Display Slider
  • Volume Retained at desired % (Default 25%)
  • Album Cover Scale to Full-Size
  • Disable Startup and Camera Legal Disclaimers
  • Change IDrive startup animation
  • Change BMW Sounds / Gongs
  • GPS Clock Sync
  • Cameras at All Speeds
  • Lane Departure Roadside Edge
  • EU SLI sign
  • Enable HUD ‘Do Not Pass/ Pass with care’
  • Blind Spot Detection at 20km/h
  • Default ACC distance
  • ↑ Traffic Jam Assistant (TJA) Max Speed
  • TJA on ALL ROADS
Appreciate 3
      11-10-2018, 09:03 AM   #3
slavearm
226
  • Disable OBD Alarm
  • Video in Motion
  • GPS Clock Sync
  • EU SLI sign
  • TJA on ALL ROADS
You list the S15A connection target, is there a macro in Launcher Pro now with these settings? Or were you referring to something else?
      11-10-2018, 09:55 AM   #4
Almaretto
Almaretto's Avatar
2373
F010 psdzdata covers F006/F010/F011/F012/F013/F018
S15A psdzdata covers F090/G001/G002/G011/G012/G030/G031/G032/RR11/RR12/RR31
I have Launcher Cheat Codes for all those.
      11-10-2018, 10:47 PM   #5
slavearm
226
Hey thats great. You have them somewhere people can reference them?
FSHNGRY2301.00
      11-11-2018, 03:30 AM   #6
Almaretto
Almaretto's Avatar
2373
Only a percentage of my Launcher Cheat Codes are publicly available. They are found here.
Appreciate 2
slavearm226.00
FSHNGRY2301.00
      02-20-2019, 12:45 PM   #7
MWcoupe
24k GOLD
MWcoupe's Avatar
148
Drives: Mineral White M4
Can someone give me the line for disable honk when locking on with engine on
      02-20-2019, 01:58 PM   #8
Almaretto
Almaretto's Avatar
2373
HORN_AT_SECURE
      03-05-2019, 04:47 AM   #9
MWcoupe
24k GOLD
MWcoupe's Avatar
148
HORN_AT_SECURE
My coder said the values are different and couldn't get it to work. Successful on your end?
      03-05-2019, 09:24 AM   #10
r33_RGSport
r33_RGSport's Avatar
12805
Drives: G09 XM, G05 X5 40, 991.2 T
HORN_AT_SECURE
Coded G15, F90, G30 all using the same lines. All worked.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
March SALES!! Evolution Racewerks - Until 04/01 | PM for DEALS
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      03-05-2019, 10:56 PM   #11
Almaretto
Almaretto's Avatar
2373
Then you used wrong coder.
Premium Launcher has old mapping, that I would not trust on G-series/F90.
Works fine with E-sysX and Pro Launcher.
      03-22-2019, 10:59 PM   #12
shellbmb
shellbmb's Avatar
197
Drives: 2022 F90 M5C
Anyone have success changing ambient lighting colors?
      03-22-2019, 11:38 PM   #13
r33_RGSport
12805
Yeap, here is the discussion from one of my customer.
https://f90.bimmerpost.com/forums/sh....php?t=1587470
      03-24-2019, 01:15 AM   #14
Almaretto
Almaretto's Avatar
2373
It is just a matter of using RGB Hex Calculator.
      07-21-2019, 03:09 PM   #15
Mxvertin
Mxvertin's Avatar
Drives: 2011 White e90 mtech 335i
I have a f90 comp and wants coding done. I live in so cal any recommended coders out there willing to help. Also lists of what can be be coded would be a plus. Thanks.
r33_RGSport12805.00
      07-21-2019, 06:07 PM   #16
boredM
124
Drives: Ford F-350 & Nardo F90
Email: sales@rgsport.com === IG: RGSport_USA
in socal, read 2 posts up
r33_RGSport12805.00
      03-08-2020, 03:43 PM   #17
ozgemiciler
Drives: bmw f15 2014
f90 gear selector retrofited to f15 , help me please
hi,
I need help with something.
my car 2014 model f15 bmw.
I want to put the f90 gear lever into my car.
I made the cable connections.
what kind of coding should I do?
Sorry for having insufficient English language.
      10-21-2020, 06:06 AM   #18
Zeezu541
21
Drives: F20 M140i || M3 F80|| F90 M5
Anyone know to increase the angel eye brightness and also enable indicators to stay on all the time like America
      11-27-2020, 11:39 PM   #19
greentrbo95gst
greentrbo95gst's Avatar
1217
Drives: 21 M5 Comp
I assume using good 'ol Veepeak and Bimmercode will not work anymore. I just took delivery of the 21 M5c and will try Bimmercode tomorrow.
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
      11-28-2020, 01:14 AM   #20
Almaretto
Almaretto's Avatar
2373
It depends on what you want to code.
      12-02-2020, 03:14 AM   #21
GAMA
///Mflight Member
GAMA's Avatar
Puerto Rico
919
Drives: 2021 BMW M5 F90 Comp
How are you bud. Trying to get ahold of you. Can you pm me please. Thanks
      12-03-2020, 03:04 AM   #22
Almaretto
Almaretto's Avatar
2373
Emailed
GAMA919.00
Search this Thread:
Advanced Search
m5post
