Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Excessive inner wear on front tires
      10-12-2018, 03:28 PM   #1
cjdzombie
cjdzombie's Avatar
76
Drives: 2011 E92 335i xDrive, M Sport
When working under the car I noticed that both front tires have excessive inner wear. The back tires are in good shape and were installed at the same time. What would cause this? What do I need adjusted? Are the tires toast?
2011 E92 335i xDrive M-Sport
MHD 93 Stage 2+ | xHP Stage 3 | xDelete | Catless Downpipe | Phoenix Racing Intercooler | ARM CP | AFE Drop In Filter
      10-12-2018, 05:12 PM   #2
Biginboca
Biginboca's Avatar
3764
Drives: 2009 E92 328i 6MT
Could be your toe is off or could be you like taking on ramps really fast.
      10-12-2018, 08:39 PM   #3
weehe126
1161
Drives: 2017 340i
Too much toe in, get an alignment.
      10-14-2018, 07:37 PM   #4
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
You can solve this problem by installing M3 control arms. They have a natural .75 negative camber and therefore do not allow for uneven wear like you are seeing on your tires.
If you are over 100,000 miles, do the tie-rods while you are in there.
      10-14-2018, 10:12 PM   #5
weehe126
1161
Drives: 2017 340i
Last time I checked you can still adjust toe with M3 control arms. I recommend them as well but the tire wear fix would come after the alignment.
      10-15-2018, 08:59 AM   #6
FCobra94
Guest
n/a
Drives:
False; inner tire wear comes from too much toe out.
You have no idea what you are talking about.
Appreciate 3
      10-15-2018, 01:21 PM   #7
parksjm7
parksjm7's Avatar
81
Drives: E92 07 335i
2007 BMW 335i  [0.00]
2002 Honda  [0.00]
Looks to be result of too much toe out / negative camber or both on front wheels
      10-22-2018, 11:32 AM   #8
cjdzombie
cjdzombie's Avatar
76
So I took the car in for an alignment and got some curious feedback. They said my camber was off and they couldn't adjust it. They said the springs were worn out and needed to be replaced. I thought that springs had a longer life expectancy. My car only has around 62K on it. I know the front shocks are probably due, but I thought I was good with just reusing the springs when I did the shock replacements. Are these guys full of it or could the springs really need replaced? They did align everything else though, so hopefully that will slow down the inner tire wear.
      10-22-2018, 11:51 AM   #9
weehe126
1161
Drives: 2017 340i
Post a pic of the new alignment sheet.
      10-22-2018, 11:53 AM   #10
cjdzombie
cjdzombie's Avatar
76
No prob. I'll post a pic when get home this evening.
      10-22-2018, 12:34 PM   #11
FCobra94
Guest
n/a
Drives:
They're idiots.
Go to a new shop.
      10-22-2018, 12:41 PM   #12
cjdzombie
cjdzombie's Avatar
76
Originally Posted by FCobra94 View Post
They're idiots.
Go to a new shop.
I had a feeling that was the case. What exactly do you disagree with? I'm still trying to narrow down what needs corrected.
      10-22-2018, 12:50 PM   #13
FCobra94
Guest
n/a
Drives:
Everything they told you.
BSM n54iS2684.50
      10-22-2018, 04:02 PM   #14
cjdzombie
cjdzombie's Avatar
76
Here is the print out they gave me.
      10-22-2018, 04:38 PM   #15
FCobra94
Guest
n/a
Drives:
cant read that
      10-22-2018, 04:42 PM   #16
cjdzombie
cjdzombie's Avatar
76
cant read that
Hmm. Wonder if the app down grades the quality. Here it is again zoomed in a bit. Not sure if this one worked either. I upload from my computer later.
      10-22-2018, 06:41 PM   #17
BSM n54iS
BSM n54iS's Avatar
2685
Drives: '11 335is | '16 Macan Turbo
cant read that
I'm cracking up
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete
      10-22-2018, 07:00 PM   #18
cjdzombie
cjdzombie's Avatar
76
Here is a link to the pic. Sorry the app uploads crap quality images.
https://photos.app.goo.gl/ZNyQCrgfUT68oyjk9
      10-22-2018, 10:04 PM   #19
FCobra94
Guest
n/a
Drives:
Omg, you paid money for that alignment!? Come on Corey...
Your "after" numbers look worse than most peeps "before" numbers.
      10-23-2018, 05:00 AM   #20
cjdzombie
cjdzombie's Avatar
76
Thay sucks. I'm not very knowledgeable about alignments. Guess I'll have to go elsewhere to get it done correctly. What are the correct specs I need?
      10-24-2018, 07:39 PM   #21
cjdzombie
cjdzombie's Avatar
76
So had the car checked by another shop and not surprisingly they found the car's alignment was jacked up. I took the proof the the original shop and got a reluctant refund. Wil be getting it corrected tomorrow.
