Custom Oil Catch Can
10-12-2018, 11:38 AM | #1 |
22
Rep 72
Just thought I'd share this little project I did recently.
I bought a radium oil catch can and RB external PCV kit so I could start catching oil on the high and low side. I made a custom bracket out of 18 GA steel. I in the future I might make a bracket in Solid Works and CNC something out of aluminum, but for the prototype, steel was perfect because I could bend it easily. The PCV kit form RB I used was Option C. I just needed to buy a few additional AN fittings form Radium to make it work. Catch can sit completely level in the bay and can be easily unscrewed by hand. I put two rubber washers behind the plate to protect the strut tower paint. Just anchored to the factory studs on the tower. Enameled bracket satin black. Turned out awesome, with both functionality and looks! Some of the photos look a little funky because I had to resize them. |
10-12-2018, 01:45 PM | #3 |
22
Rep 72
I'm running the BMS high side OCC like normal and then running the low side radium can directly tapped into the manifold. The pictures make it look a little crooked but it's not.
