BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Fuel Pump error Idrive message after lpfp stage 2 upgrade
      10-10-2018, 06:01 PM   #1
cristy7610
Romania
37
Drives: BMW E92 335I
Hi guys
Few days ago I upgraded my lpfp to stage 2 on my 335i n54 2009, FBO stage 2+MHD and all was good until yesterday when I speed up on a highway and after that I received on my Idrive a message about fuel pump and exclamation sign on my dash bord...after I let the gas pedal, the message disappeared in a few seconds and most of the times I get this message on Idrive when I floor it.
I ' ve checked with MHD and I get only a shaddow code ; 2AAE DME:FUEL PUMP.The car runs very good, only get this annoying message.
I replaced today my HPFP and have exactly the same errors with fuel pump on my idrive.
I made some logs and I'll appreciate if someone could take a look, maybe is something wrong here.
I read on other forums and most of the 2009 model have this problem after upgrading to stage 2 lpfp and most of the cases was a easy fix by updating EKP module....
Is it the same case here?*
I made a log today and maybe someone is able to see what is the problem here, also my lpfp and hpfp are in parameters?
https://datazap.me/u/cristy7610/mhd-...=3-11-14-19-20
      10-10-2018, 06:37 PM   #2
IllSic_Design
IllSic_Design's Avatar
2124
Drives: 09 E92 335i
Your rail pressure and lpfp pressures are good.
From Fuel-It's website:
"Upgraded pumps pull more current, so if your EKP (LPFP control module) is weak, it may overheat causing it to shut down and need to be replaced. If this is a concern for you checkout our FI-650HP fuel pump upgrade kits that retain the stock LPFP and add a secondary pump."
Decent thread with info from Fuel-It here; https://www.n54tech.com/forums/showthread.php?t=34215
      10-10-2018, 06:58 PM   #3
cristy7610
Romania
37
Thank you for your reply.
Your offer sound good, but I already upgraded to stage 2 and I read some similar cases where the culprit was EKP module, or have to modify some values to stop this warning message on I drive
      10-10-2018, 07:01 PM   #4
IllSic_Design
2124
Drives: 09 E92 335i
Not sure what you are talking about, I didn't offer to sell you anything. I sent you a link with info on your issue??
      10-26-2018, 07:16 AM   #5
335e92tx
ahat
335e92tx's Avatar
1036
Drives: Was '07-335e92 - Now '13-335IS
Yes, several threads around that the version 2 of the module can be associated with it. Its unclear what cars started getting version 3s. I have recently installed a S2 pump and the alert came up once. BUt I haven't done many highspeed run since.. The #3 modules generally run about 50$ on ebay and as I understand, dont require recoding after install.
If it happens to me I am gonna try replacing it bc those things drive me nuts.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos.
https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8
      04-29-2019, 01:15 PM   #6
Blown95ImpalaSS
72
Drives: s54 e36 m3/4/5
Bumping this thread. Installed new bucketed fuel-it stage 2 LPFP in my late 2009 n54 and logs look perfect, but I'm getting fuel pump message on idrive and chime every time I turn the car off. Tuner says its related to voltage threshold in the EPKM and is mostly harmless but it's driving me nuts.
Is there a way to modify the voltage threshold for the EPKM via NCS, bimmergeeks pro tools or similar? Searched for days and read about similar issues, cant find a straight answer. Here's a link to similar problem/solution on n54tech if it helps at all:
https://www.n54tech.com/forums/showt...t=42012&page=2
      04-30-2019, 10:41 AM   #7
Milan
202
Drives: F80 M3
The proper solution is to get the torqbyte controller from EOS. Anything else you do is just a bandaid fix.
EKPM3 is in 09+, it's better but will still fail eventually.
17 M3 Comp
      04-30-2019, 12:40 PM   #8
Blown95ImpalaSS
72
Interesting. I was told the voltage threshold just needs to be adjusted in the existing EPKM via NCS expert or BG pro tools but I'm a technical moron. The EOS module also seems overkill for those of us sticking with basic aftermarket fueling setups (single lpfp). Have an appointment Saturday AM with a local advanced coding guy, will update the thread.
Appreciate 2
      05-01-2019, 04:45 AM   #9
cortez08
60
Drives: 2008 335xi
My 2008 335xi has an EKPM3 from factory. It’s throwing the code on a stage 2 lpfp as well. I have a brand new EKPM3 getting coded tonight. I considered the EOS torqbyte but it’s expensive. If I was running dual pumps I would of bought that instead. In hindsight I probably should of just bought it for a dual pump and just wired it for a single if that’s possible.
FWIW I pulled the side seat cover off and left the module exposed to keep it cool and I haven’t had a fuel pump code since. Someone needs to make a heat sink unit. I bet that would solve most issues.
      05-03-2019, 02:21 PM   #10
Blown95ImpalaSS
72
Stoked to report that, using the n54tech post as a guide, remote coding worked! No more error message on Idrive or chime. You do NOT need to purchase new EPKM modules or that Torqbyte unit. The steps outlined in NCS allow for voltage threshold adjustment.
Two monster thumbs up for Alex @ Alpine coding. He helped me install VMware on my old mac, and did the whole thing remotely via bimmergeeks cable in 15 mins. Even easier for Windows users. Alex@alpinemss.com
C.Pop64.50
      02-08-2021, 05:45 AM   #11
cristy7610
Romania
37
Open this post again, due to the same problem...today I've contacted Alex, maybe he could help me.
Is it anyone here who could confirm if Protool could code this module to avoid that error in I-drive?
      02-08-2021, 07:15 AM   #12
cruizinmax
33
Drives: 99 Civic, 09 335i
If you have protools there is a fuel pump voltage fix option in there. Using that fixed the error on my 09.
      02-08-2021, 09:50 AM   #13
lookalikehuuh
700
Drives: 2006 330i, 2007 335i
Hey fellas,
I had same issues when I upgraded my LPFP to Walbro 450. Turns out my EKPM was probably overheating. I followed the procedure in this thread and haven't had any issues with codes since then.
https://www.e90post.com/forums/showthread.php?t=1737938
cky7515.00
      02-10-2021, 03:50 AM   #14
cristy7610
Romania
37
I've followed the solution posted in this video and after this no more errors or anything else..Easy fix.
Appreciate 3
      04-05-2023, 01:35 PM   #15
erqizz
Drives: E92 335i
I sent you a private message could you please check
      06-27-2023, 10:31 AM   #16
2blackbimma
2blackbimma's Avatar
Drives: 2008 Bmw 335i, 2008 Bmw 328i
I have a 2008 335i e92 fbo stage 2+ 135k miles. Just installed stage 2.5 lpfp (not E tune yet). I went to drive and as soon as I try to do a little pull I get 2aae code from mhd so I just clear and nothing really happens. Will putting those thermal heat sinks pads inside of the ekpm sensor help in this situation?
      12-22-2023, 11:32 PM   #17
titan.n54
Drives: BMW 335i
2007 BMW 335i  [0.00]
Did you resolve it?
